Old 01-20-2021, 09:46 AM #1
bmwahba46 bmwahba46 is offline
bmwahba46 is on a distinguished road
Oil Leak - Need Help with Possible Causes
Hey guys,
I have noticed a large amount of oil on the underside of my rig, and need some guidance on things I should look into.
My valve covers are leaking (have been since I bought the truck a month ago) so these are first on my list. Parts are on order and waiting delivery.
But I am concerned about the amount of oil here. After the VCG job, I will clean and monitor, but I wanted to get a headstart in possible further diagnosis in case that is not the cause. I noticed oil on the bottom of my skid, dripping onto the oil pan, and traveling all the way back the side of the block. In my experience, valve cover leaks are slow and small, not this amount of wetness. Is it possible that this could all be from the VCG?
I am slightly concerned so have parked the truck for now.
On my list is the oil cooler o-rings, and also the rear main seal. I am really hoping it is not the rear main!
I have taken some photos:
Leak - Album on Imgur
anyways, long-time lurker here so happy to be a part of this forum!
bmwahba46 is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 10:02 AM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Hopefully just valve covers. They can leak a lot. The half-moons and cam-cover in the back leak. Use a new tube of Toyota FIPG. I did it twice.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 10:02 AM #3
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
The leaking valve covers are indeed able to cause all that (from the pictures I see that do load).
I would not over-worry the situation and just pull the skid and clean it up. Then BEFORE doing any further work, clean the rest up as best you can - engine cleaner in a can and a pressure washer. This will give you a fresh opportunity to find the actual leak(s) and you can proceed from there.
I have a '98, bought 2 years ago as a fixer-upper for my still-not-driving-age daughter. One of the last things on the list is valve cover gaskets & timing belt etc. this summer (2021). It leaks enough that on a 2 mile driver training / mail box run you can smell the oil burning off the exhaust. It's been this way since I bought it. However, that "much" is barely enough to affect the oil level. I think I've only added oil once.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 10:19 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Like others have said, it's very possible that it is your valve covers/half moons leaking that much. Fix that first, give it a thorough cleaning/degreasing and then reevaluate before fixing/replacing anything else. If it does leak again and it's difficult to pinpoint where it's coming from there is oil dye that you can add which will be visible with a UV light.
Old 01-20-2021, 11:10 AM #5
Boom, thank you all so far. I am glad I was on the right thought process as to getting this sorted. I had the VCG's on the backburner while I fixed a few other projects on the truck, but once I saw the oil seem to lose more and actually dampen the skid and all the underside of the pan, I am now prioritizing it.
I have new OEM VCGs, half moons, OEM FIPG, and all the spark plug seals etc on order. Fingers crossed I can fix this easily without too much further diagnosis.
The rear main seal is my only true worry, as I'd have to have a shop do that rather than DIY... so let's see.
Old 01-20-2021, 12:05 PM #6
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
As long as you have enough oil I don't think you need to park it until you do the vcg's.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 03:00 PM #7
Yo CBlock! Small world lol.
You know how I am... overly cautious. Only reason I wanted to park it, was I am not sure its the VCG's...but I'm sure it's fine. My BMW's leak oil at the valve covers all the time but it is never a large amount, usually slow small drips and seepage.
I haven't lost anywhere near enough to sway the reading on the dipstick, so far. But when the VCG's were leaking a weak ago, they weren't this bad. Once I saw a bunch of oil stain on the bottom of skid plate, I just wanted to make sure it wasn't something that could lead to a worse problem.
As far as I know, these really only leak from VCGs, half moons and cam plugs, RMS, or the front cam seals in the timing belt area.
Old 01-20-2021, 03:38 PM #8
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
1) hope its just your vc gaskets, betting it is, its just rust proofing the bottom of truck now.
2) Ive also seen the oil cooler leak and for me with my big hands its a pain in the arse, and if you do have to replace the o rings, replace the hoses too
3) A friend had a leaking taco, some yahoo shop did an oil change and the rubber seal had seperated from the old filter and stuck to the engine, and they just slapped on new filter, am totaly amazed it threaded on and sealed and did not leak more than it did. He does not take to anyplace for oil changes now, he does them. But it was obvious it was leaking at filter base. After not being able to tighten, we pulled it ( and they had really cranked it on hard), found the extra gasket, and replaced with a YDD3
4) Hope its not rear main seal
Old 01-20-2021, 03:44 PM #9
cblock406's Avatar
cblock406's Avatar
Glad to see you on this forum!!!
@projects_always
Old 01-21-2021, 11:41 AM #10
spartacus's Avatar
spartacus's Avatar
Here is a really detailed video from @mtbtim
3.4 L V6 5VZ-FE Toyota 4runner, Tacoma, Tundra Valve Cover Gasket Tutorial - YouTube
Old 01-21-2021, 12:31 PM #11
Originally Posted by spartacus View Post
Thanks! I've watched it. I hope to tackle the job early next week.
Old 01-22-2021, 03:14 PM #12
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
If it's leaking from the back I would suspect either the halfmoons or the rear main seal. If it is the latter then you're usually better off just running thicker oil to slow the leak.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 03:49 PM #13
Well, hoping its not the RMS.
Old 01-30-2021, 07:20 PM #14
Angry
Welp. Valve covers are done, it was definitely leaking. But.... I peaked underneath today and I still found some fresh oil. Frustrated.
It’s definitely coming from the back of the motor somewhere. I found fresh drips near the steering rack, and it drips down to the backside of the oil pan.
Could this be a rear main? Kind of running out of things to check here.
Old 01-30-2021, 07:29 PM #15
Attached some photos:
Leaking - Album on Imgur
amount , concerned , list , noticed , oil
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
bad oil leak help please OsaFsb Classic T4Rs 11 01-23-2011 09:13 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
