Old 02-08-2023, 08:30 PM #31
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Hey guys, I rebuild these. I have a few kits in stock. If you check the classifieds you’ll see my posts about it. Feel free to PM me if you want.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 12:32 AM #32
Tibor Tibor is offline
Tibor is on a distinguished road
Thanks for the reply, pardon my inability to navigate through this forum, but for some reason I cannot find the button to PM you. I think it's safe to assume that my account being to new prohibits me from messaging privately. Not sure if you can PM me though?
Tibor is offline   Reply With QuoteReply With Quote
Old 02-22-2023, 08:37 PM #33
JHUNT#3 JHUNT#3 is offline
JHUNT#3 is on a distinguished road
Looks like I stumbled across this too late with the kits no longer being available and JZiggy just running out too...
For people who have done this / handled these door checks before, what are your thoughts on converting a RH check to a LH one? I know they're different PN's and not directly interchangeable, but seems like the only difference between the sides is the orientation of that end piece "lug" on the body interface side of the bar - if you can remove that big pin and re-pin it with that lug flipped, it looks like that would convert a RH to LH or visa versa (am assuming they use the same piece parts but are assembled as mirror images).
My passenger side is pretty stiff so may just swap that with the driver's side one as a temporary improvement, unless I'm missing something.
JHUNT#3 is offline   Reply With QuoteReply With Quote
Old 02-23-2023, 10:04 AM #34
JZiggy's Avatar
JZiggy's Avatar
You should be able to swap side to side. The little covers on the frame side will sit upside down but who cares?
Once I get access to kits again I'll make rebuilds available...
Old 02-23-2023, 05:20 PM #35
Ok sweet. Wasn't sure if that 10mm bolt was offset vertically from the bar at all or not (if so there could be some misalignment if flipped). I'll give that a try this weekend, thanks!
Old 05-11-2023, 01:35 AM #36
Forgot to follow up to confirm this is the case ^. The arms of the door checks themselves are identical and have one side marked "L" and the other "R", so just assembled as mirrors.
I wasn't able to de-pin the lug off the end to reassemble/convert them with the tools and patience I had on hand that day, but I'm sure it's possible.
Here are a couple pictures of the RH check in the LH spot.
Door Stopper Repair-img_0658-jpg
Door Stopper Repair-img_0659-jpg
@jziggy , aka , door , learned , repair
Help! Door actuator repair gone wrong. Can't open door at all. hellabove 4th Gen T4Rs 20 03-29-2018 09:29 AM
Post-Accident Door Repair? LawnDart 5th gen T4Rs 4 06-13-2016 12:41 PM
door ding repair? luv2eat 5th gen T4Rs 5 04-18-2011 12:45 PM
