Old 01-23-2021, 03:05 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
For those with Kings, what's the lift at the lowest setting?
I know "setting" isn't really the right word since they virtually have an infinite range to crank and adjust...so maybe say "at the lowest adjustment". Whatever... haha
Basically I just need to know if at the lowest setting they add any lift or not. Or do they start at 0?
Old 01-23-2021, 03:56 PM #2
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
(nearly) Everything you wanted to know about King shocks.
https://www.youtube.com/watch?v=-MsKf1lIYI0&feature=youtu.be
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 04:19 PM #3
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
It all depends what rate coils you have. The higher rate, the less preload. In my case I’ve got 650lb coils, 0 preload 2.75” lift, with stock weight on the front
ax2021 is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 11:37 AM #4
jross20's Avatar
jross20's Avatar
Shit, [snip] 2.75 is way too high for me. I really only want about 1 to 1.5".
When you say preload, I assume you are talking about cranking them down? So you're really getting 2.75 inches at the lowest setting?
Okay so mine are coming with 600 lb coils.
Old 01-24-2021, 01:31 PM #5
Correct. Well if you’re going to get 600 lb coils and your goal is ~ 1.5”, definitely don’t touch adjustment ring, 0 preload and see what you get. Good luck with your Kings!!!
Old 01-24-2021, 05:21 PM #6
jross20's Avatar
jross20's Avatar
I guess I need to expedite my arb bumper purchase... Or I'll find out soon if I need it sooner... Haha
Ugh, just bought the kings
Old 01-25-2021, 01:58 PM #7
thenightman's Avatar
thenightman thenightman is offline
Real Name: keith and jenny
thenightman will become famous soon enough
Dang, I have 700# coils on mine. Been waiting to get installed for years. Right now they are adjusted down about 1.5", I'll adjust them to zero before putting them on. Hopefully that won't give me any more then 3" of lift.
Build thread
http://www.toyota-4runner.org/3rd-ge...ncemobile.html
Few dollars, and fewer sense
thenightman is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 03:44 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I wouldn't use 700# coils on a 4runner without any substantial additional weight on the front end. That is going to make for a very stiff front end. I wouldn't want any higher than 600# with a stock front end if it was me.
basically , haha , lift , lowest , setting
5th Gen 3" Lift: Kings Extended Travel vs Old Man Emu BP-51 dwib44 5th gen T4Rs 2 11-29-2020 06:54 PM
TRD coils/5100 on lowest setting + 890's? lgc285 3rd gen T4Rs 1 05-16-2020 06:24 PM
Toytec 3" lift set to lowest settings? Ogbassist182 4th Gen T4Rs 12 03-07-2016 09:27 AM
Anyone run their Tundra TRDs/5100s at the lowest setting? danthemanx07 3rd gen T4Rs 11 03-13-2014 01:54 PM
A/C very cold on lowest setting but hot at 70 degrees F4injected 4th Gen T4Rs 6 06-02-2013 08:51 PM
