Old 01-24-2021, 03:47 AM #1
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Not a “max spare tire size” question
I’d rather ask, what is the most appropriate or acceptable sized spare to have in conjunction with 285/75/16 BFG KO2s.
I wouldn’t care if it was a bald 225/75/16, highway tire as long as it worked as was the same diameter.
Any recommendations?
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 03:17 PM #2
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
What, for your spare? My vote goes for same size if it will fit.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 03:34 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
use same size diameter if possible, width does not matter, if not then only use spare when NOT in 4wd and only to get you to a repair.
Old 01-24-2021, 03:50 PM #4
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
The obvious answer is another 285/75/R16 BFG KO2. If you are looking for an alternative tire which will keep the same diameter but be narrower, I'd recommend using something like this to see how tire sizes compare. Remember that anything you go with that keeps the same diameter as your non spare tires will run into the same packaging problems if you are trying to put it on the stock spare tire carrier.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 10:46 PM #5
TankerTrooper TankerTrooper is offline
TankerTrooper is on a distinguished road
Try to find a used 255/75R16 tire by searching CL in your area. It is nearly the same diameter (+0.9% difference). A fair number of trailers run that size.
TankerTrooper is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 01:02 PM #6
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
You're meaning 255/85r16, I'll bet.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 05:07 PM #7
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about
thatoneguy's Avatar
Just spit-balling ideas here, but what about that same size, aired down (possibly flat), and keeping an air pump on board? Would it fit in the spare space if flat? Is this otherwise an awful idea?
2023 TRD Offroad Premium, nautical blue
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 10:45 PM #8
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
This is what I do. But still says low under the bumper. It will definately catch obstacles offroading and leaves me wanting a rear tire swing out to avoid the hassle of dragging it on obstacles. So it's not an ideal solution if you plan to wheel. If you don't wheel this will work fine for you.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
care , ko2s , spare , tire , wouldn’t
V8 Towing Package Spare Tire Size Question atalarico 4th Gen T4Rs 27 11-04-2021 11:27 AM
Spare Tire location tire size limits Ogre75 5th gen T4Rs 3 03-06-2020 01:11 PM
Spare tire size - v8 Billynath1988 4th Gen T4Rs 7 10-23-2015 06:51 PM
Spare tire max size ameining 3rd gen T4Rs 4 07-24-2011 11:43 PM
Spare Tire Size? CJ3Flyr General Discussions 4 06-15-2008 08:25 PM
