Old 01-24-2021, 11:59 PM #1
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
tube steel crossmember rotted by gas tank
I have some rot in the round tube steel cross member between frame rails near the rear of the gas tank. This crossmember supports a bunch of stuff like the upper suspension links, gas tank, etc. Mine is rotten towards the middle and has developed a crack. What I want to do is just slide a smaller diameter tube right into the existing tube, throw a couple welds in there, and call it a day. The existing tube is not in the worst of shape, it is just really banged up in the middle by the crack. I searched and was surprised that this repair has not been discussed before. Has anyone else had to do something like this?
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 04:37 AM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
You should take a picture and upload it so we can see and tell what can work or not.
2000 4Runner Limited 4x4 V6
Old 01-25-2021, 03:15 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
@brillo_76 has done it. He's the man on fixing up these frames. I believe he has done just as you mention. Check out his build section.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 05:34 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup use a black steel pipe 43 inches long with a close to 2inch outer diameter. I clean the old cross member tube out. then coat it with FF and slide a new one inside. Once that done. I weld it on the ends and then Weld the brakets to it in the thin spots. As brackets can be welded to the new inner pipe super easily.
Old 01-27-2021, 01:44 AM #5
You mean like a regular schedule 40 black steel pipe for plumbing natural gas? Is the 2” black steel pipe a nice tight fit?
Old 01-27-2021, 03:49 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes... Its slightly smaller but welds in greatly.. being the rust will swell. I use black pipe like natural gas plumbing 1/1/2 inner diameter... which is close to 1/4 ich thick is super close to 2 inch outer diameter slightly less then that but close.
IF you have find a pipe a little closer that steel it will work great. This is the closet pipe that i came across easy to get ahold of that works. :-)
Old 01-27-2021, 11:56 PM #7
Right on thanks! From my rough measurement I will need about a 2-1/16" outer diameter pipe. I may actually hit up a fabrication shop this weekend. I am gonna pull into the parking lot, take a rear tire off, and just throw pipes in there until I find one that fits the best!
Old 01-28-2021, 12:06 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The chances of you getting a 2 and 1/16 OD pipe to go through a rusted tube cross member is extremely unlikely.
I actually had to pound my pipe in with a sledge to get it in as they rust and rust expands the rotting steel.. hence why I dropped the size slightly.
Old 01-30-2021, 03:38 PM #9
I ended up getting a piece of 2" outer diameter steel pipe from a local steel supplier. Are you ready for this......the walls of the tube are 1/2" thick! They had it laying around and I paid $30 for it. Like you said the frame was in bad shape inside and there is no way it was simply going to go through. So I reamed out the frame with a 2" diameter hole saw to clean up the rust inside. Then I greased up the new pipe and rammed it through. I also had to use a sledge to get it through. I didn't have to pound on it as hard as I could but it definitely needed some force. I put a couple small welds on the end, probably didn't even have to do that.
So in the end a 2" outer diameter pipe would probably go right through if the existing frame wasn't already that damaged from rusting on the inside.
existing , gas , middle , tank , tube
Wishing to buy 3rd gen flat Steel or tube bumper Chodymace94 Want to Buy/Trade 0 09-26-2013 04:18 AM
wtb:00-02 gas tank and fuel neck tube matthinnant Want to Buy/Trade 0 10-17-2012 04:35 PM
BudBuilt Light Steel 1/8 Gas Tank Skid better than OEM? ColoradoFrosty 5th gen T4Rs 7 07-30-2012 12:30 AM
Aluminum vs Steel tube bumper? AF808fighter 3rd gen T4Rs 1 02-14-2012 03:33 PM
