Old 01-25-2021, 09:19 AM #1
Temple90 Temple90 is offline
Temple90 is on a distinguished road
New noise coming from trans tunnel area
My 99 SR5 has a noise that just started coming from the trans area. Noise is there while in gear or in neutral, but only while driving. At idle it goes away.
I uploaded a video of the noise below:
4runner noise on Vimeo
Temple90 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:47 AM #2
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
You mentioned only while driving but not at idle. Is there a certain RPM at which it begins? In gear but off the gas does it continue? See if you can play with different driving patterns and gear selections (AWD, RWD, 4WD, Drive, 2, 1, Center Diff Lock) to create changes and use that to narrow down the origin. If it is replicated in Neutral without moving, have a friend keep it above idle while you go underneath to determine if it is from the tranny or TC.
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 01:27 PM #3
spartacus's Avatar
spartacus's Avatar
I am guessing so could be some thing else. Only while moving makes me lean towards the rear differential whine or double cardan joint going out. Is your maintenance up to date? vis à vis when were the atf, both diff and transfer case. Changing fluids and greasing joints wouldn't hurt. If your rear differential is going out 75w140 might buy you some time.
Old 01-25-2021, 08:30 PM #4
vwbus vwbus is offline
vwbus is on a distinguished road
I can't really hear anything.
vwbus is offline   Reply With QuoteReply With Quote
area , coming , noise , trans , video
noise coming from engine/need help 1990silverbullet Classic T4Rs 7 01-24-2018 01:01 PM
I got a clickity Clackity noise coming from rear diff area bassmacka 4th Gen T4Rs 5 04-21-2017 05:46 PM
Where's the noise coming from? pedalquickly 3rd gen T4Rs 26 02-28-2014 09:32 PM
Cant tel if this a normal sound or not. coming from trans area twitchee2 3rd gen T4Rs 6 09-17-2011 01:11 PM
Noise coming from engine thehadley4 3rd gen T4Rs 2 07-28-2010 10:38 PM
