Old 02-06-2021, 04:42 PM #16
nobb nobb is offline
nobb is on a distinguished road
As long as the boot isn't blown and the grease is still in there, I've never heard of an OE axle developing play under normal circumstances.
If you don't want to spend the money on CVJ, the next best thing is to get an OE axle from the junkyard and rebuilding it with the OE boot kit. Thermoplastic is the OE material and is far superior to neoprene which is what all the other rebuild kits use.
With a 3" lift, a diff drop is also mandatory to straighten out the angle IMO. No CV boot is going to last more than a couple years with those extreme angles. I've been changing out my CV boot every 1-2 years thinking that different brands would be better, but they are all the same. Finally caved in and did a diff drop which is what I should've done from the beginning.
nobb is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 02:16 PM #17
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
OEM rebuilt axle shaft part number
What would the correct OEM part number be for the following:
2002 4Runner converted to manual hubs?
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 08:26 AM #18
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
SonoranSteel did a write-up and included the part numbers:
Technical Articles : Sonoran Steel Fabrication LLC, Toyota Truck Parts
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 02:02 PM #19
Originally Posted by G_Raw View Post
8inch conversion been done... just no write up
https://www.fourwheeler.com/features...ve-to-be-weak/
If you cruise independent you'll find a thread or two of 1st gen Tacomas that have done Tundra 9" diffs ( really 8.7 I believe) by doing some narrowing work. They run 37s no problem with that setup.
I did see that article previously, I just can't find any detailed information about what it actually takes to make it happen. I have searched and searched but I just can't find anything
Old 02-14-2021, 11:06 AM #20
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I suspect it'll take some narrowing work to clear things. Modifying of diff bracket arms to sit correctly. Or build custom bracket arms. Custom CVs from someone like RCV to go from 8inch to our ifs hubs. Stock CVs may work depending on how long or short you need em. If need longer Tundra CVs maybe applicable to the situation. Lastly swapping front driveshaft or lengthening/shortening for optimal angles once the front axle is in place.
Seems like a bit of work for cool points when someone stops you at the mall to ask about your rig. I'd need to murder a few 7.5 diffs first or be looking to build a rig to race KOH personally to make me consider it doing all that work.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 12:12 PM #21
G_Raw's Avatar
G_Raw's Avatar
Looks like I was pretty close based on this...
Front diff upgrade time. - Toyota 4Runner Forum - Largest 4Runner Forum
Old 05-07-2022, 01:43 PM #22
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
anybody have a part number for the NAPA maxdrives? their current online listing does not have any indication... hopefully they didnt do away with that product line.
Please Wait... | Cloudflare
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 11:52 AM #23
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Not entirely sure about Napa MaxDrive, but I just had these 1258's installed. They're Napa Heavy Duty CV's. So far they've performed excellent (knock on wood) although I'm only DD'ing my rig these days, and the occasional drive on sand when at the beach.
Napa Heavy Duty Axles
Old 05-08-2022, 01:58 PM #24
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
3rd gen front cv axles.
I’m pretty sure the 1258s are exactly the same as the TrakMotive TO8043ET Extended Articulation CV Axles that O’Reilly sells?
If so, then they’ve been great for me. So far about 6k miles with some moderate wheeling as well.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 04:58 PM #25
JoeT4R's Avatar
JoeT4R's Avatar
I honestly had no idea about that. That’s good to hear you’ve had good results with them so far. Like I said, I only DD my rig nowadays so my only concern is the boot tearing. I drove around for a few years with ripped boots and thankfully I along with the truck was okay. But I’m very pleased with how they Napa ones turned out. Have you had any boot rippage or any rusting so far?
axle , dif , front , side , splines
WTB: 3rd Gen OEM Front Axles CB3G_GM Want to Buy/Trade 3 05-31-2021 02:06 AM
Front axles sal6430 4th Gen T4Rs 2 06-08-2014 08:35 PM
WTB: Transfer case, front differential, front axles for 1st gen 1989 V6 5-speed Entropy85 Want to Buy/Trade 0 05-26-2014 10:52 AM
Need NEW FRONT AXLES Trdsupranick Maintenance/Detailing 16 04-30-2013 01:41 PM
wtb: 4th gen front axles Bangers Runner Want to Buy/Trade 0 03-05-2012 02:10 PM
