Old 01-25-2021, 12:46 PM #1
jrkiernan's Avatar
jrkiernan jrkiernan is offline
Real Name: Josh
jrkiernan will become famous soon enough
jrkiernan's Avatar
Real Name: Josh
3rd gen front cv axles.
Ok, I have a 2000 t4r sr5 3" toytec lift on 33" BFG KM2 and stock 4.10s. This weekend I snapped the passenger side front axle. The splines are still in the dif and I can pull the axle on the dif side out to see that the brake is where the splines meet the smooth part. I am looking into axles and noticed my axle nut is 35mm and the Oriley and most non-OEM are 42? I also am looking at the CV Ultimate IFS Axle set. However, they are $2K and I'm wondering if anyone has these. This is much more expensive than a $200 OEM axle and I am not sure if I would need to swap anything else out.
This is also one of my daily drivers and I don't go crazy with it but this weekend it broke in Folsom and I was luckily able to tow it to San Jose. So any advice???
jrkiernan is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 04:31 PM #2
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
I have a 4th gen with the toytec 3” and I just put some of the CVJ remans on.
CVJ Axles - CV Axles & Steering Racks for all your needs
I installed them last week and went out yesterday and they seem the be working great so far.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 05:05 PM #3
jrkiernan's Avatar
Real Name: Josh
jrkiernan's Avatar
Real Name: Josh
Thanks,
I just spoke with them and it sounds like they have a great product.
I appreciate the info.
Old 01-25-2021, 05:24 PM #4
phattyduck phattyduck is online now
Axle nuts are either 35mm or 36mm. I just bought both to make sure I have what I need...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 01-25-2021, 08:08 PM #5
cas5259 cas5259 is offline
cas5259 is on a distinguished road
Lol 2k for axles?? At 1k each, you could replace a $45 rock auto axle every month for almost 2 years and break even.
Is OEM the way to go for CV’s? Just put in a new Cardone - will see how long it lasts. Couldn’t justify $200 for something that’s so easy to replace. You’re lifted though, so that’s gotta take a toll on axles.
cas5259 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:46 AM #6
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Personalty I would convert to manual hubs and run OEM axles with silicon boots and carry aftermarket spare axles before I'd spend two grand on just axles.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 08:32 PM #7
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
4rth gen front diff
Would someone please install a 4rth gen front diff so we can use better axles!!! I've been waiting to see a write up.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 10:21 PM #8
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Have you been able to get the splined shaft out of the diff yet?
I've had that type of break before. I ended up getting a long drill bit from one of the tractor supply stores and a small slide hammer from Harbor Freight. The end of the slide hammer had 1/4x20 threads. So I used the long drill bit to drill into the piece of shaft that was stuck in the diff, tapped it with a 1/4x20 tap, then screwed the slide hammer into the shaft. A quick tap with the slide hammer pulled it right out. The shaft was surprisingly soft and easy to drill from what I remember.
midcoma is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 10:28 PM #9
pharcyde145 pharcyde145 is offline
Real Name: Matt
pharcyde145 is on a distinguished road
Real Name: Matt
That's a clever way to do it. I'll have to make a note of it for if/when it happens to me.
pharcyde145 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 11:39 AM #10
jrkiernan's Avatar
Real Name: Josh
jrkiernan's Avatar
Real Name: Josh
I have not. I am waiting for space in a buddy's shop to work on it as pulling everything apart in the rain sucks. also I don't have space in the driveway at the moment. I appreciate all the info and advice. As far as I know, OEM is the way to go unless you are doing KOH with ifs or have deep pockets.
The aftermarket ones seem to have more voids in the metal than the OEM do making them easier to snap. The ones from RCV seem to be a harder metal combo but are $1,995 for the set +tax and shipping.
The CJV ones are OEM reman with upgraded bearings and inner boot for $274 ea +$95 core. Not bad as that's what OEM will cost. The aftermarket ones that I have found are much cheaper but I have had these in my 4runner for less than 20k miles and broke it. I don't pretend to know all the ins and outs of the metals or the products that are sold but if I can go with an OEM or CJV I think I will. I like the manual hub conversion and am interested in the 4th gen diff swap. Thanks again for the info.
Old 01-28-2021, 11:56 AM #11
Bassturd's Avatar
Bassturd's Avatar
Dealing with CVJ was amazing. I called and talked to the gal that answered the phone she couldn’t answer all of my questions then a tech/mechanic got on the phone and answered all of my questions. They told me there was a 2 week back order and I received an email 4 days later letting me know that they shipped out. I sent my cores in Monday and had already received the core refund by Wednesday.
2004 SR5 V8 AWD
Old 02-04-2021, 11:47 AM #12
jrkiernan's Avatar
Real Name: Josh
jrkiernan's Avatar
Real Name: Josh
Ok, so I can not get the broken axle out of the shaft. new OEM axles and shaft with bearing and seal. Hopefully, this won't happen again.
3rd gen front cv axles.-axle-1-jpg  3rd gen front cv axles.-shaft-jpg  3rd gen front cv axles.-shaft-2-jpg
Old 02-04-2021, 05:58 PM #13
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
There are plenty of threads on this. RCV 2K axles are for lifted trucks who wheel every weekend & don't need cheap Cardones snapping everytime you're out on the trail. Trail repairs get old real fast. The CVJ's are next in toughness at around $500-$600 a pair. OEM Rebuilds & Napa's MaxDrive (New) seem to hold up & are what most of us who dont rock crawl buy. Do not buy any aftermarket rebuilds even if only doing dirt roads. New Napa's are the same price or only a few dollars more.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 09:14 PM #14
jfeltT4R's Avatar
jfeltT4R jfeltT4R is offline
Real Name: Jake
jfeltT4R will become famous soon enough
jfeltT4R's Avatar
Real Name: Jake
NAPA axles are the way to go. Lifetime warranty so if you tear a boot take it back and get a new one. I've been running them for about 7 years now and only had to change two. LOT's of miles. I've found that spraying some silicone lube on the boots before a long drive helps a lot. Easy preventative measure
jfeltT4R is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 11:17 PM #15
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
8inch conversion been done... just no write up
https://www.fourwheeler.com/features...ve-to-be-weak/
If you cruise independent you'll find a thread or two of 1st gen Tacomas that have done Tundra 9" diffs ( really 8.7 I believe) by doing some narrowing work. They run 37s no problem with that setup.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
axle , dif , front , side , splines
WTB: 3rd Gen OEM Front Axles CB3G_GM Want to Buy/Trade 3 05-31-2021 02:06 AM
Front axles sal6430 4th Gen T4Rs 2 06-08-2014 08:35 PM
WTB: Transfer case, front differential, front axles for 1st gen 1989 V6 5-speed Entropy85 Want to Buy/Trade 0 05-26-2014 10:52 AM
Need NEW FRONT AXLES Trdsupranick Maintenance/Detailing 16 04-30-2013 01:41 PM
wtb: 4th gen front axles Bangers Runner Want to Buy/Trade 0 03-05-2012 02:10 PM
