Old 02-21-2021, 03:02 AM #16
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
I've been running this setup for several months and really enjoying the ride.
There was a few weeks where I thought the ride was too firm - but then I replaced the hard plastic polyurethane Rear endlink bushings with rubber ones and it made a huge difference to the ride comfort.
*Also, I'm running MStud's endlinks in the front and 2nd Gen Rears on the rear.
Anyone Running Toytec Boss 2.0 Front Aluma Series Coilovers?-screenshot_20210220-225536_gallery-jpg
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 08:37 PM #17
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
There was a few weeks where I thought the ride was to firm - but then I replaced the hard plastic polyurethane rear endlink bushings with rubber ones and it made a huge difference to the ride comfort.
What's the rake like after it settled? Did you max out the front coilovers to 3 inches? I recently put mstuds link all around but I believe the bracket bushings are polyurethane ones from energy suspension.
That's awesome that you are the original owner of your 4runner man.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 10:39 PM #18
TRD 4RNR's Avatar
TRD 4RNR's Avatar
I wanted to be slightly higher in the rear so the fronts are not maxed out (see attached)
I've been meaning to take measurements I'll try to get some tomorrow.
I'm still running polyurethane up front - but changing the rear endlink bushings to rubber was a huge improvement in comfort.
And thanks - when the color matched bumpers became a thing - I pulled the trigger.
Anyone Running Toytec Boss 2.0 Front Aluma Series Coilovers?-screenshot_20210221-183354_gallery-jpg
Old 02-23-2021, 09:11 AM #19
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Ya'll's rigs are looking good! I have had Toytec Ultimate coilovers before with their 550lb springs and I thought the ride was perfect. When I installed my life I had a lot of driveline vibration around 60 as well as the all so popular issues with my CV boots busting. Are ya'll having any of these issues or any issues, for that matter? I'd really like to put this setup on my current 4Runner but don't want to push myself into unnecessary issues. Its pretty solid right now.
Thanks.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 11:16 AM #20
Dom8706's Avatar
Dom8706's Avatar
Thanks.
Did you put in a diff drop kit and get an alignment after installing your lift?
Old 02-23-2021, 11:47 AM #21
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Thanks.
Those are common issues with any 2.5-3” lift. Both my stock CV boots leaked grease and eventually busted the boots after I put my first lift on (close to 15 years ago now). But that’s just what happens to CVs when you change their angles after sitting at stock height for so long (especially the original CVs). I’ve broken a handful of CV axels on the trails over the years, and I’ve never had a new CV leak. They get used to the steeper angles right off the bat, unlike stock CVs.
I have had to replace a couple u-joints over the years too, but that’s to be expected with a 200K mi. truck. The lift probably didn’t help things, but like the CVs, I never had that issue again once I put in the new u-jpoints. And like Dom8706 said, a diff drop will help the stress on your CVs and definitely an alignment is necessary after a lift.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 10:12 PM #22
TRD 4RNR's Avatar
TRD 4RNR's Avatar
Center Hub to Fender Flare measurements:
LF 22.75" ¦ RF 23.00"
LR 23.50" ¦ RR 23.50"
Old 02-23-2021, 11:01 PM #23
Dom8706's Avatar
Dom8706's Avatar
Nice that's pretty much perfect imo.
Old 02-25-2021, 10:47 AM #24
Thanks man, and yes I did install one. I guess that's what I found as well, once I put new CVs in they didnt bust again. My stock ones are currently not busted but if I do go for this setup again I will just replace them while I'm in there.
How low would you all say you can crank them down without rubbing on 285s?
Its hard to get the height just right being everytime you make a change technically you need another alignment.
I didn't rub on mine at all before but I put the coilovers on and left them where they had them adjusted and I think they were pretty maxed out on height.
01' SR5
Old 02-25-2021, 02:37 PM #25
brian2sun's Avatar
brian2sun's Avatar
I wouldn’t replace the CVs while you’re in there. Besides removing the tire, there really isn’t anything else in common with the coilover install and a CV install. I’d just see how it goes. You could also put some better clamps on the boots with the CVs in place IF they start to leak after the new coilovers.
Lift really has nothing to do with rubbing, because when the tire is stuffed, it’s in the same spot lift or no lift. The lift just makes the tire father away from being stuffed at rest, so it won’t rub as easy on road as no lift. I would install the coilovers with the factory setting and adjust them on the truck as necessary if you want it higher or to level it out. Minor adjustments don’t require a realignment IMO. When you have a passenger or put in/take out anything big in the truck, it changes the ride height a little bit (but it’s not like you realign everytime you have a person in the car or haul something big). After cranking the collar 1 full turn down to lower the passenger side, and one full turn up to raise the driver side, my Alumas sit exactly 1/8” higher than my old 883s. I didn’t even bother with an alignment and it drives perfectly straight. I’ll just keep and eye on my tread wear over the next 5000 or so mi. and make sure there isn’t any uneven wear.
The Alumas aren’t set at max from the factory. Max is 1.06” (IIRC) of thread, and I think mine were set at about 5/8” (pass) and 3/4” (driver). You can crank the collars up a few times from factory before reaching max. One full crank of the collar up/down = roughly about 1/8” more/less lift on mine.
Old 10-27-2021, 10:48 AM #26
Zachpins34's Avatar
Zachpins34 Zachpins34 is offline
Real Name: Zach
Zachpins34 is on a distinguished road
Zachpins34's Avatar
Real Name: Zach
Hey, wanted to see how you’re liking these Alumas after some time. I just ordered a set with a 600# coil (no weight up front, but I’d like to get a bumper soon) and am a bit apprehensive to install since I’ve heard some mixed reviews.
How is the ride / quality?
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
Zachpins34 is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 09:15 PM #27
TRD 4RNR's Avatar
TRD 4RNR's Avatar
I love the ride and the height. But I'm also 95% on road.
I also got rid of all the Energy Suspension Swaybar Endlink Bushings I had on there and went back to stock.
Took the 4Runner camping last month loaded with gear and it ran great.
Anyone Running Toytec Boss 2.0 Front Aluma Series Coilovers?-screenshot_20211031-181318_gallery-jpg
Old 11-02-2024, 12:55 PM #28
PAMTB252 PAMTB252 is offline
PAMTB252 is on a distinguished road
Angry Toytec Boss Aluma Coilover FAILURE
buyer beware on these Aluma Coilovers. Had these for 3 years with almost no off roading besides some fire roads and started getting a lot of bad squeaking for few months followed by clunking. I took a closer look and looks like the shaft sheared off and shock is bending (Which was causing the rubbing/squeaking). Not good. I have a call into Toytec to see what they say..
Anyone Running Toytec Boss 2.0 Front Aluma Series Coilovers?-toytec-boss-alumina-failure-2024-jpg
PAMTB252 is offline   Reply With QuoteReply With Quote
coilovers , pics , ride , running , wondering
We Switched to ToyTec's Aluma Series 2.5" Coilovers WanderlostOverland 5th gen T4Rs 1 01-24-2021 04:28 PM
Help with installing Toytec Boss Aluma 2.0 on KDSS 4Runner Kyle B Engines / Suspension / Wheels / Tires / Audio / Accessories 4 05-08-2020 04:30 PM
Toytec Aluma Series Boss Kit MOONMAN5 5th gen T4Rs 2 08-24-2019 10:26 AM
New Toytec Boss Aluma Series Kit and Dobinsons Upper Control Arms MOONMAN5 5th gen T4Rs 0 07-31-2019 02:30 PM
Toytec Boss 2.5 series coilovers Billynath1988 4th Gen T4Rs 18 10-15-2017 08:23 PM
