Old 01-27-2021, 11:19 PM #16
jonfasch jonfasch is offline
jonfasch is on a distinguished road
A funny for Dragon_EX...
I'm driving my 16 year old son home from Youth Group... and I talk about tearing apart the dash to fix the green 4WD light...
And I mention your chat above, and notice I have no lighted D symbol on my dash either. All the others P,N,R,1,2 all work fine.
So looks like I have another bulb to fix. Thanks for the heads-up on this one! :-)
jonfasch is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 11:37 PM #17
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by Dragon_EX View Post
... just seems like a lot of work just for a single light.
Takes about 10 minutes to R&R, easy peasy...
Old 01-28-2021, 05:31 PM #18
Dragon_EX Dragon_EX is offline
Dragon_EX is on a distinguished road
Ha! Now I wonder if it's a common thing. It must burn out quick with it being lit up all the time.
Dragon_EX is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 05:58 PM #19
I did just assume that since it's the gauge cluster it would be hard but it looks straight forward enough, and while I'm in there I can replace the other bulbs too. I'm guessing I can just buy #24 and #74 light bulbs on Amazon or something and put them into the same plastic base, right? No need to find a set of ones with the base already on them?
Old 01-28-2021, 06:57 PM #20
Yes.. it does look pretty straightforward. My only concern is disconnecting the 5 cables... Otherwise looks okay.
I'm not sure on the bulbs myself, so I ordered standard replacements from the local dealer for the 2 I needed. I'm sure I overpaid, but I need them by this Saturday and it's my only vehicle - so wanted the correct ones before tearing it apart. and then being stranded with the wrong ones.
Old 01-28-2021, 07:17 PM #21
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Tip: If they are bulbs which I believe they are, buy "bulb condoms" of the proper colors.
I had to replace a few lights in some of my other Yotas, and the condoms always cracked when trying to swap from the old bulb to new.
Not sure if these are proper, but they show the pic.
Pinball Life: Bulb Caps/Condoms
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 08:58 PM #22
Do you know if the green color is the same for all the bulbs? And I'm guessing the color of a new bulb cover is going to be a little different from the original bulbs.
As a side note it seems the correct size of bulb for the drive light and the other lights of the same size is E74 rather than #74. Apparently there's a distinction between regular #74 and E74 . I think I'm gonna buy the bulbs and covers from McMaster-Carr because it's the only place I can find that isn't a suspicious looking seller on eBay or Amazon. Part numbers are 9527T992 and 16925K12 for anyone playing along at home. Just searching for the right bulb has turned out to be an oddly deep rabbit hole for just some light bulbs.
Old 01-28-2021, 09:48 PM #23
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I'd go with VLED. If you want to, Superbrightled also has what you are looking for. If you are replacing the gauge back lights, the 74's from superbrightled will hot spot much more than the ones from VLED. For the rest of them, the one's from superbrightled should be fine. I wouldn't go with the LED's from McMaster-Carr. They look like they are the correct base, but they are super low output. The incandescents should be okay though.
Edit: 74 is the correct size. It looks like E74 and 74 will both work as the base is the same, but they have different bulb diameters. The E74 is slightly smaller, so it shouldn't be an issue.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 09:54 PM #24
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If you bought OEM bulbs they come with the bulb condom if originally supplied, swap and you will be good to go.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 10:23 PM #25
Well, I'm not looking to have the super bright and super green LED dash lights like it shows in the pictures on their website, I have a soft spot for the ugly puke-ish green of the gauge lights. And I think what I found on McMaster-Carr are the incandescents. I'm gonna keep looking though because now I don't really want to be buying a pack of ten of these things. The regular 74 bulbs are definitely more common then E74 so if it's really not a big deal I'll just go with 74.
Old 01-29-2021, 12:56 AM #26
The 74 incandescents on McMaster-Carr are 1505K359. I'm not sure if you actually need to worry about the condoms. I don't know that any of the cluster lights except for possible the gauge back lights use the condoms. I think they are all just clear bulbs and the tint is actually in the cluster itself.
Old 01-29-2021, 01:56 AM #27
benny_js benny_js is offline
benny_js is on a distinguished road
4wd light not on
Hey folks, I just bought a 2006 4runner sports edition. I just realized that the odometer isn’t adding up more mileage even though the trip does go up and the speedometer works fine. I also just realized that there are no lights on the dashboard that refer to the 4wd or diff lock at all. I can feel the 4lo engaging and even the beeping if not engaged correctly but no light on dashboard whatsoever. Same thing with the diff lock, if I press it, nothing turns on, so my concern is having it in without me knowing. Lastly, i also noticed that my dashboard doesn’t seem to have the drawing or figure for the 4wd, in other words, I believe that even if the lights or bulbs weren’t working, the dashboard itself doesn’t show the option for them.
HELP!!!
benny_js is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 01:59 AM #28
Is there a way a 4wd 2006 sports edition came without the dashboard lights for 4lo, 4hi or diff lock. Because i just got one with 170,000 and i can feel the 4lo engaging but nothing turns on on the dashboard and the dashboard itself doesn’t have the drawing (like without the light on you can still see them you know) on it.
Help.
Old 01-29-2021, 02:19 AM #29
HELP!!!
Help.
You are in the 3rd gen forums. Your 2006 is a 4th gen. Try the 4th gen forums.
Old 01-30-2021, 12:49 PM #30
My Saturday task was to pull the instrument cluster..
I was a bit shocked that from the time I opened the hood (battery disconnect) until I had the cluster out was truly less than 10 minutes. Piece of cake as previously mentioned. Just took a few minutes to disconnect the 5 cables behind the cluster. 15 minutes to put back together and test.
My only issue is that the Toyota Dealer ordered the wrong bulbs for me. I had a bad feeling when I picked them up – as they were green and looked almost big enough to put on your grandma’s Xmas tree… Well not quite that big… but close.
So I did some bulb swaps while I had it apart and now my other set (upper) of 4wd lights(wheels) work. And my D symbol (Drive) now works. Funny –but I have no idea how long the D has been out – nice to have it back. So I truly did have just a bulb issue and not a 4wd issue as I initially thought. I like bulb issues. Lol
A few hints.
1. Test ALL your cluster lights prior to removing the cluster just in case you have more bulbs that are out. Almost all can be tested either when turning on the vehicle, using that bulb functionality, or almost running your gas tank dry (I did this to test that light).
2. Disconnect the 5 cables from the left (Driver’s) side – it’s easier than getting in from the right.
3. When the cluster is out, shine a flashlight in the bulb hole to figure out which warning light is which.
4. There is a Washer Fluid warning light hole (as mentioned in another post), but there is no electrical connection or socket to that bulb location.
5. I did map out every warning light on my cluster and will post in a few days – I hadn’t been able to find anything online that matched my 2002 4Runner to this point.
6. You can pull the bad bulb out of the socket with a pliers (but only use a very light grip).
Posting a few pictures.
1. First one is my working upper 4wd lights (before it was the bottom)
2. Second is the 5 disconnected cables
3. Third is the back of the instrument cluster
4. Fourth is with the white cover plate removed
5. Fifth is showing access to the three 4wd light sockets at top middle (empty socket at bottom center is the inoperative Windshield Washer socket)
6. Sixth is the 2 light bulbs I need (small one is for 4wd, large one is for almost all other indicator lights)
Thanks again for everyone’s help and info on this. All the little tidbits from all the posts really helped in knocking this out.
Again I’ll post a layout of the back of the cluster and what each hole is mapped to in a few days.
2002 4Runner 4WD Dashboard Lights only Half Working-1-jpg  2002 4Runner 4WD Dashboard Lights only Half Working-2-jpg  2002 4Runner 4WD Dashboard Lights only Half Working-3-jpg  2002 4Runner 4WD Dashboard Lights only Half Working-4-jpg  2002 4Runner 4WD Dashboard Lights only Half Working-5-jpg  2002 4Runner 4WD Dashboard Lights only Half Working-6-jpg
4runner , 4wd , dash , i’m , wheels
1997 - 2002 3rd Gen 4Runner Back Half Wanted Fair Oaks CA 95628 Toyotadude88 Want to Buy/Trade 2 11-20-2015 09:22 AM
Dashboard lights up, A/C stops working suddenly..FIXED! spanvs888 4th Gen T4Rs 1 05-03-2014 11:59 AM
Installed new radio now dashboard lights aren't working Deputy1211 3rd gen T4Rs 4 08-21-2010 11:52 PM
2002 4Runner Dashboard + rear lights out Unoose Problems & Warranty Issues 0 12-23-2007 08:28 PM
