Old 01-30-2021, 12:59 PM #31
jonfasch jonfasch is offline
jonfasch is on a distinguished road
Originally Posted by Skulking View Post
The 74 incandescents on McMaster-Carr are 1505K359. I'm not sure if you actually need to worry about the condoms. I don't know that any of the cluster lights except for possible the gauge back lights use the condoms. I think they are all just clear bulbs and the tint is actually in the cluster itself.
Correct - All are clear bulbs with the tint in the cluster faceplate.
jonfasch is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 01:05 PM #32
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
@jonfasch Not sure if you need it, but for the two bulbs you posted a picture of, the larger one should be a 74 which you can just pull out of the base to swap in a new 74. The smaller one is a Neowedge. From the picture I can't tell if it is a T3 or a T4, but for that one the entire unit is replaced.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 01:21 PM #33
Yes... Thanks! I was able to pull the larger one out of the socket with the light grip of a pliers. My fingers kept slipping.
Old 02-05-2021, 11:23 AM #34
Okay... I finally have all the instrument cluster bulbs switched out that either were bad or I wanted to replace. I replaced all 3 Gauge Backlights (green condoms) with just the default clear bulb (I like that better).
I did pull out the console approximately 8-10 times - as I initially had the incorrect bulbs on hand when replacing for a few of the locations, and while testing a few others. I have it down to 7 minutes from opening the hood (disconnecting battery) to having the instrument cluster on the workbench. Easy-Peasy now...
The only bulb I'm unsure of is the A/TP bulb. I never could get that bulb to light after replacing the bulb, and the socket multiple times. It doesn't light when starting the vehicle, and it doesn't light when putting the 4WD in neutral and trying all the other shifting options... I'm not sure what is up there.
Anyway, I'm good with it now - and really like having almost all working as needed.
Though I do have VSC Off / VSC TRAC / Check Engine Light on ALL the time. But I've had these 3 lights on since 2007 within a month of buying the vehicle with about 55,000 miles... I just went over 320,000 a week or so ago.
Attached is a layout of the Instrument Cluster bulbs use, color, and bulb number. I searched hard for this exact layout online previously - but could not find one.
Old 02-05-2021, 03:11 PM #35
That light is purely 'mechanical' - it should only light with the vehicle 'ON' the trans in Park and the transfer case in neutral. Likely just a dirty switch on the transfer case. It is pretty unimportant - it just tells you that the parking pawl in the trans won't stop the truck from moving even though the truck is in Park. Most people here probably have never even seen it turn on...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-05-2021, 04:10 PM #36
Your comment...."should only light with the vehicle 'ON' the trans in Park and the transfer case in neutral."
I tried that exact situation multiple times with different bulbs and sockets... So I'm guessing you may be correct. As I feel I remember that light lighting up years ago... but I rarely do anything with the transfer case.
Maybe just a quick spray of electrical cleaner one of these days on the plugs when it gets above zero here... :-)
Thanks!
4runner , 4wd , dash , i’m , wheels
1997 - 2002 3rd Gen 4Runner Back Half Wanted Fair Oaks CA 95628 Toyotadude88 Want to Buy/Trade 2 11-20-2015 09:22 AM
Dashboard lights up, A/C stops working suddenly..FIXED! spanvs888 4th Gen T4Rs 1 05-03-2014 11:59 AM
Installed new radio now dashboard lights aren't working Deputy1211 3rd gen T4Rs 4 08-21-2010 11:52 PM
2002 4Runner Dashboard + rear lights out Unoose Problems & Warranty Issues 0 12-23-2007 08:28 PM
