Old 01-27-2021, 02:00 AM #1
Chmteacher Chmteacher is offline
Chmteacher is on a distinguished road
Red face 98 jerking at higher speeds
Hi all,
When in 3rd to 5th gear at 2-3000k rpm my 98 3.4L 4Runner with 120k miles studders during acceleration, not while idling or cruising speeds. I've installed a new fuel filter, air filter, and throttle position sensor (TPS) without improvement. The spark plugs were done about two years ago and the auto shop said there are no error codes on testing.
What should I do next?
Thanks for your help!
Chmteacher is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 10:04 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Chmteacher View Post
Hi all,
When in 3rd to 5th gear at 2-3000k rpm my 4runner with 120k miles studders during acceleration, not while idling or cruising speeds. I've installed a new fuel filter, air filter, and throttle position sensor (TPS) without improvement. The spark plugs were done about two years ago and the auto shop said there are no error codes on testing.
We'll need to know what year and engine your 4Runner is to be any help
Old 01-27-2021, 07:37 PM #3
It's a 1998 four-wheel drive 3.4L
Old 01-27-2021, 07:39 PM #4
98 3.4L 4wd
Old 01-28-2021, 10:28 AM #5
Real Name: Patrick
Real Name: Patrick
98 3.4L 4wd
I had a similar problem that ended up being a faulty coil pack. It would run better when I first started up and would get worse the longer I drove. Under load the engine would misfire/stutter more. All three coil packs tested within toyota specifications, but one of them had a lower resistance value than the other 2 and once it got hot enough it wouldn't spark strong enough.
Old 01-30-2021, 01:42 PM #6
If that were the case wouldn't I have a misfire code (which I don't)?
Old 01-30-2021, 02:40 PM #7
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Mine did that too, was also a bad coil pack and it took forever to throw a code. I think it did it for 6 months before a code popped up
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 03:38 PM #8
spartacus's Avatar
spartacus's Avatar
Same scenario but mine ended up being an injector.
Old 01-31-2021, 01:52 PM #9
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
I had the same issue but mine turned out to be the boot on a spark plug wire allowing the spark to leak to the head. At first it was only under serious load but it eventually became an issue at almost any speed. Found out exactly what it was one day when it was humid out and could actually hear and see it arcing at idle. Also didn't throw any codes until just before I was able to diagnose it.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 02:42 PM #10
19963.4lsr5 19963.4lsr5 is online now
Same for me and the 97 Puppy Hauler. One of the coil boots had a hole burned through it from the spark under load.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 02-01-2021, 10:43 AM #11
jfeltT4R's Avatar
jfeltT4R jfeltT4R is offline
Real Name: Jake
jfeltT4R will become famous soon enough
jfeltT4R's Avatar
Real Name: Jake
Troubleshooting ignition problems can be annoying. I think codes are not thrown until a misfire occurs a certain number of times within a specified time frame (I might be totally wrong here)
I'd pull check plugs even though they were replaced not too long ago. They could be indicating another problem you have leading to this issue. Just make sure none of them are fouled up.
Check coils and compare resistance. As others have said, one may not be providing the umph needed for good spark anymore.
Check your ignition wiring.
A nice little upgrade for these old trucks would be to just go ahead and replace all plugs, coils, and ignition cables with new. I used NGK plugs, OEM coils, and NGK wires. The engine ran noticeable better after that. Good luck!
jfeltT4R is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 12:40 PM #12
Real Name: Patrick
Real Name: Patrick
It took 2 months before it finally set a misfire code. I ended up downloading a bootleg version of toyota techstream on a crappy laptop I had to look at live data.
Old 02-11-2021, 02:57 PM #13
Well, I went ahead and replaced all three coil packs and six spark plugs. The old plugs looked like they had regular wear. It didn’t shake for about a week but started again yesterday; apparently that wasn’t the problem. Any further guidance?
Old 02-11-2021, 03:12 PM #14
spartacus's Avatar
spartacus's Avatar
Ohm out the injectors 13ohms at 20*c 16* if hotter.
Old 02-11-2021, 05:37 PM #15
No idea what that means but I’ll try to find some video on it. Thanks!
ago , filter , spark , speeds , years
Transmission Slipping/Jerking at Low Speeds when applying gas? EveningCommuter 3rd gen T4Rs 5 10-19-2020 02:30 PM
Jerking brakes / low speeds Traveler74 General Discussions 11 07-21-2020 10:05 PM
Transfer Case disengaging/engaging poorly at higher speeds nalbertasr5 3rd gen T4Rs 7 11-22-2015 11:36 PM
Jerking in 4Lo daisy Problems & Warranty Issues 1 05-26-2015 02:28 AM
Wheel bearings? Vibration higher speeds Crusher1122 4th Gen T4Rs 7 10-29-2013 03:58 PM
