Old 01-28-2021, 09:03 PM #1
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
Clunk from under drivers footwell
The past few weeks there's been a lingering cluck under my feet whenever the back of the truck goes over a bump. It not just 1 clunk, it does it a couple times per bump. I cannot for the life of me figure out what it is. At first I thought it was the steering rack since I feel it in the steering wheel too, so I replaced everything I could without replacing the rack itself but no luck. Has anyone else experienced something like this?
nathanroyse is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 09:15 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I recently had to replace my Prothane anti-sway bar bushings because of a rattle over 3" bumps, everything else is new from suspension, LCA bushings, LBJ OTR, sway bar links,.. I put the prothanes on early in 2018, had to replace them again a week ago, the bar bushing on one side had 1mm play, went with the same ones again #18-1115., I think my sway bar has/had corrosion where the OEM bushing was, I tried OEM bushings and they all tore out after a year even when I cleaned the corrosion off better, so I've just stuck with poly.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 09:36 PM #3
Interesting. I removed my sway bars entirely because I thought that's where the noise was coming from.. its not so much of a rattle, its a clunk and it sounds like its coming from right underneath me when im driving.
bump , clunk , rack , steering , thought
water in drivers footwell after hard rain bigtimeweb 3rd gen T4Rs 6 06-03-2020 05:33 PM
Clunk on drivers side front swansong04 5th gen T4Rs 22 12-19-2018 04:15 AM
Rotational clunk under drivers left foot 4.7Runner 4th Gen T4Rs 2 09-01-2014 02:43 PM
clunk going over bumps on drivers side front freshley 3rd gen T4Rs 3 07-27-2012 04:18 PM
Clunk/Loose Drivers Seat Iron Clad Lou Problems & Warranty Issues 4 11-17-2006 04:43 PM
