I recently had to replace my Prothane anti-sway bar bushings because of a rattle over 3" bumps, everything else is new from suspension, LCA bushings, LBJ OTR, sway bar links,.. I put the prothanes on early in 2018, had to replace them again a week ago, the bar bushing on one side had 1mm play, went with the same ones again #18-1115., I think my sway bar has/had corrosion where the OEM bushing was, I tried OEM bushings and they all tore out after a year even when I cleaned the corrosion off better, so I've just stuck with poly.
