Old 01-29-2021, 05:30 PM #1
gruenegenes gruenegenes is offline
gruenegenes is on a distinguished road
Long Crank Time
First time post. I really appreciate all I've learned from you guys.
I know, long crank time is a common topic. I've read every thread. Some multiple times. I also recognize this is a common issue to 3rd gens, but this is my daughter's car and I don't want to risk her getting stuck somewhere. Here's what I've done so far:
- Checked and cleaned all grounds in the engine compartment
- Replaced plugs
- Replaced plug wires
- Replaced battery
- Replaced fuel filter
- Replaced air filter
- Replaced PCV valve
- Replaced fuel pump and pump screen
- Replaced front (AF) and rear O2 sensors
- Cleaned MAF sensor
- Cleaned throttle body
- Disconnected battery to clear memory
- I don't smell any fuel in the fuel pressure regulator vent line
All of this work - primarily the O2 sensors, the fuel pump and the grounds - reduced the crank time, but it's still longer than normal. What's odd is that sometimes it's longer than others, so the problem has an intermittent flavor to it.
I'd really appreciate any recommendations on what to do next. I'm thinking of fuel pressure regulator, coolant temp sensor, intake air temp sensor, IAC valve...... I'd really like to know how to test these items or any others before simply replacing the part.
2002, SR5, 4WD, 170,000 miles
gruenegenes is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 05:37 PM #2
What do you consider longer than normal?
3 plus seconds before the engine starts is normal. The fuel pump only starts pumping when you engage the starter.
Don’t compare the 4Runner to an American vehicle when at key on the fuel pump runs 3 seconds to pressurize the fuel rail.
Old 01-29-2021, 05:50 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Do a compression test on each cylinder. It could tell the health of the piston rings. On cold startups, it takes a bit longer than usual but when its warmed up, it fires up real quick. At least thats with my car.
EDIT: When was the timing belt replaced?
2000 4Runner Limited 4x4 V6
Old 01-29-2021, 06:15 PM #4
Dragon_EX Dragon_EX is offline
Dragon_EX is on a distinguished road
I assumed the 4runner did the same thing, running the pump at key on. Mine takes a little long to crank and it worried me a bit but if this is the case then I guess I shouldn't be worried every time I start the engine.
Dragon_EX is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 06:31 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Time it with a stopwatch on cold starts and let us know what you come up with.
Old 01-29-2021, 07:14 PM #6
It isn't just common. It is how they were from the factory... Mine has been in the family since new and has always taken 2+ seconds to start. In its old age now, it sometimes takes a second round of starter engagement (I stop after about 3-4 seconds).
It is by far the 'longest' starting of any of the vehicles I have owned (other than old manual choke carbureted stuff) - including other Toyotas. (My '89 Camry takes barely a tap of the key to start) But guess what? The 4Runner has always started over its 298k miles.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-29-2021, 07:57 PM #7
spartacus's Avatar
spartacus's Avatar
4runners lack the prime circuit for the fuel pump like most other cars thus it takes longer cracking. yet the fuel pumps last a long time.
Old 01-29-2021, 08:25 PM #8
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
Try turning it to the "on" position before starting it. This gives the fuel pump a longer chance to engage before attempting to start.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 12:07 AM #9
Prior to the work I did, the crank time was 2+ seconds. I have it down to about 1.5 seconds. But sometimes it’s way longer and sometimes you have to stop cranking and turn the key again. Doesn’t matter if engine is hot or cold. Strange
Old 01-30-2021, 12:26 AM #10
spartacus's Avatar
spartacus's Avatar
Injector leak can also be a cause of long cranks. Wouldn't hurt to inspect the spark plugs for black suit.
Old 01-30-2021, 01:18 AM #11
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Which is kind of weird because my experiences with LS400's were not 3 seconds or even 2 seconds... but virtually instantly. I've never seen an engine start so fast, especially in 40 F
Almost like it was "frozen" in a running state and the key unfroze it. So crazy.
Old 01-30-2021, 01:34 AM #12
fixxor fixxor is offline
fixxor will become famous soon enough
This was the cause for my long crank.
fixxor is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 11:22 AM #13
My rig is right around 2 seconds. It does annoy me it’s not an instant start it was one thing I had to get use to.
Old 01-30-2021, 12:02 PM #14
jross20's Avatar
jross20's Avatar
So what is considered normal? Mine tends to take from 2-3 seconds.
You know, sometimes... rarely, the starter seems to remember it's youth and turns the engine over with piss and vinegar making it start in what feels like 1 second.
What controls starter speed? Maybe we all have worn out starters...haha.
Old 01-30-2021, 09:56 PM #15
That’s an interesting point. Here’s a pic of one of the plugs I changed last month. Does this look like a sign of an injector leak?
Long Crank Time-5e575b4a-6dd5-40bb-b356-e807ba5dc6d4-jpg
cleaned , crank , fuel , replaced , time
Long Crank Time? Jebb209 3rd gen T4Rs 21 04-18-2020 08:53 PM
Random long crank time CO_SR5 4th Gen T4Rs 3 02-01-2018 01:01 AM
1992 4runner will crank for a long time then finnally start, then wont have problems timcarl450 3rd gen T4Rs 0 03-25-2013 05:23 PM
Long, inconsistent, crank T4RBoarder 4th Gen T4Rs 0 09-01-2010 10:55 PM
