Old 02-01-2023, 10:44 AM #16
Dragon_EX Dragon_EX is offline
Dragon_EX is on a distinguished road
Originally Posted by Frankers View Post
Hi I have the exact same situation right now where my upstream A/F Sensors is holding at around 0.6V and my downstream O2s will either fluctuate or hold between a slightly higher voltage. Did you end up figuring out the issue?
Sorry for the really late reply but I ended up replacing the entire exhaust and it was able to finally fix the code. Unfortunately not a quick and cheap fix! I think the main reason was because only 1 catalytic converter was new and there was also leaks along the entire exhaust. So I gave in and spent the money on an all new exhaust, from the catalytic converters to the tail pipe, and it finally got rid of that cursed code. It's been several months now and everything is still going strong.
Dragon_EX is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 12:47 PM #17
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
My P0420 was simply a too-loose exhaust pipe coupler on a section of the cat-back exhaust system I bolted on. Just mentioning it because this code can be triggered by leak issues past the sensor and cat(s) and can be a free fix.
Old 02-20-2023, 07:04 AM #18
Frankers Frankers is offline
Frankers is on a distinguished road
Thanks for the replies. I did the reverse shopvac plug into my exhaust pipe today to check for exhaust leaks and sure enough the gasket between my front and rear cat is blowing air! Gonna try to patch it/replace the gaskets and give it another go. Will keep everyone posted
Frankers is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 09:53 AM #19
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Would you be able to post up a pic for reference of where your leak was coming from? I've had the P0420 for the past 10 years and I've just let it ride.
Not sure if I need new cats or if I have a leak. Never put the time/effort into really trying to get it squared away.
Sent from my SM-S908U using Tapatalk
Old 02-20-2023, 02:23 PM #20
Real Name: Blair
Real Name: Blair
My situation might be a bit different because the kit I am running has multiple bolt-together segments and resonator. That's where my leak(s) were. Besides the main flange behind cat 2 on a CA rig, I'm not sure if there are any other junctions beyond the cats in the stock pipe. Now that I think about it, I had to cut the stock pipe with a small hand-held hacksaw to get it out because I couldn't wiggle it out sitting on the ground. Have you looked for small rust holes along the system? My leak(s) were downstream of the 2nd O2 sensor. I'd look at any other possibility before buying a cat.
cat , catalytic , p0420 , problem , rear
error code p0420: O2 sensor or catalytic converter? fan of fanboys 3rd gen T4Rs 4 03-23-2020 02:22 PM
Catalytic Converter P0420 Cali Emissions jjf8 3rd gen T4Rs 12 08-01-2019 09:12 PM
Catalytic Converter Replacement (P0420) fish0281 3rd gen T4Rs 13 11-15-2014 06:29 PM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 3 06-07-2011 08:18 AM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 2 06-06-2011 11:08 PM
