Old 01-30-2021, 07:39 PM #1
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
Ultragauge/DTE
I tried to search, but could not find the answer. I was wondering if I added an Ultragauge would the DTE be more accurate than the gas gauge in my 96 4runner? Usually when my gas light comes on it only takes around 14 gallons to fill up, never anywhere near the 18.5 gallons the tank is supposed to hold.
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:02 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Yes. Once you get the ultraguage set up and calibrated it seems to be pretty accurate. It’s mpg calculations are pretty close to what I calculate at fill up.
I’ve set my tank size to 10 litres smaller so that at the empty point I’ve still got a touch in there. I didn’t like the dte value counting on a dry tank as I would never go that low.
It’s a good device, worth the money. My favourite feature is the alarm on coolant temps.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:25 PM #3
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
My cluster gauge behaves the same way and it seems to be pretty common. I have an UG as well, and it's good to have a second, more accurate opinion on levels.
Old 01-31-2021, 12:25 PM #4
Ok thank you. Ya I don't generally run my vehicles much below 1/4 tank before filling up. But those vehicles aren't telling me I'm at empty either with only using 3/4's.
Old 01-31-2021, 01:48 PM #5
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
There's something like 2 gallons that are below the pickup for the fuel pump that you will never use so although it is "empty" it really isn't.
Wedgy is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 06:27 PM #6
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
I can confirm this.
When I first got my ultragauge and calibrated everything, I set the tank at 18.5 gallons. The lowest I ever was on fuel was when my UG said exactly 2 gallons to empty, literally right as I was pulling into a gas station my fuel pump started to suck up air and my engine started to sputter slightly. I now set my UG to 16.5 gallons, knowing that 16.5 gallons truly is the limit.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 08:42 PM #7
Originally Posted by Team_Jake View Post
I can confirm this.
Good info to know, thanks
gallons , gas , light , supposed , takes
96 Ultragauge FrogginAround 3rd gen T4Rs 8 06-03-2020 05:34 PM
Ultragauge? flooredrunner 3rd gen T4Rs 3 05-21-2020 07:44 PM
About to buy an Ultragauge... thegipper General Discussions 23 03-01-2017 12:38 AM
UltraGauge wfo9 5th gen T4Rs 16 02-18-2017 01:56 PM
