01-31-2021, 10:36 PM
Ultragauge and Transmission Temps
Any way to monitor transmission temperatures with the ultragauge?
Posted is a picture of the settings for a 1st Gen Tacoma but ECU differences must be why I can't monitor it -
02-01-2021, 01:30 AM
Real Name: Blair
Real Name: Blair
I haven't gotten around to adding the trans temp codes in my UG yet, but I would like to.....
Edit - edited.
02-01-2021, 01:14 PM
The code you entered is correct. The transmission temp can only be read through OBD2 on model years 99+. What is your model year?
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
02-01-2021, 01:21 PM
Real Name: Patrick
Real Name: Patrick
Here's the setup for transmission temperature for 99-02 4Runner's for anyone else that's wondering
TData: 686AF101B40000
TCtl: 85
RCtl: 00
RPos: 2808
Mtch: 41B400
X: 0009
/: 0005
+: FFD8
Out Format: 00
Ave: 00
Left/Right: 31
02-01-2021, 01:34 PM
Oof, makes sense.
Mine is a '98
02-01-2021, 02:48 PM
Real Name: Blair
Real Name: Blair
TCtl: 85
RCtl: 00
RPos: 2808
Mtch: 41B400
X: 0009
/: 0005
+: FFD8
Out Format: 00
Ave: 00
Left/Right: 31
Thank you!
02-02-2021, 03:46 AM
Real Name: Blair
Real Name: Blair
Doin 69 with a hot tranny?
Sorry to barge in here, but thanks to the above info I finally got my UG displaying one of the most important functions I originally got it for. I could have been more creative in hindsight, but those were the first two 3-character strings that popped into my mind when naming the function. Now I need to find the healthy range (?) and see what it does climbing the local mud/snow trail in 4L
02-02-2021, 09:55 AM
Real Name: Patrick
Real Name: Patrick
I don't remember where I came across the info, but 210-220*F trans temp is what I consider to be the caution area and will either turn OD off if travelling at highway speeds or shift the transfer case to low range if offroading.
02-02-2021, 12:34 PM
Is there an idiots guide walkthrough on where to enter that info? I also originally bought mine to monitor trans temp but have instead spent my free moments doing other electrical stuff
02-02-2021, 01:36 PM
Real Name: Blair
Real Name: Blair
Navigate to the page below on the device and you will see how you can set the parameters. It's a bit tedious but you'll get the hang of it quickly. It helps to have the info shared above printed and with you. I did it while waiting for my son's dentist appointment. I Googled Ultragauge Mgauge Programming or something on my phone.
Menu > Gauge/Page Menu... > Select Gauge/Page > M Gauge Setup.
Select an unused MGauge page (I used 1) and start pushing buttons to edit fields.
Voila!
02-02-2021, 03:48 PM
Viola!
Thanks, that worked! In other news, I have decided to recommend programming an ultragauge to the dept of defense as a highly effective, non-lethal form of torture
02-02-2021, 03:58 PM
Real Name: Blair
Real Name: Blair
HAHA 8-Bits of agony (with the engine running the whole time, too).
02-02-2021, 06:27 PM
Real Name: Patrick
Real Name: Patrick
You can turn the ultraguage on with the key on engine off by pressing or holding the top button on the back. Just an FYI since it took me a year to figure that out on my own lol
02-02-2021, 07:06 PM
Real Name: Blair
Real Name: Blair
HAHA awesome! I wondered about that.....
12-29-2021, 11:02 AM
Real Name: Brad
Real Name: Brad
Now I have lots of questions before I order.
2000 Sr5 Sport Auto. I will definitely be monitoring Trans temps. Thanks for the info on that. But Which model did you get?
-UltraGauge MX v1.4
Please note that the MX v1.4 does not contain the added features found on the UltraGauge EM Plus THIS MAKES ME QUESTION.
or
-UltraGauge EM Plus v1.4
I think The EM Plus sounds more user friendly. I have read the literature, but still not totally sure. When in doubt copy someone else I guess.
2000 SR5 Sport 4WD, A/T, E-Locker, 285k, no lift, 265/75/16'S
Mods- ISR, Deckplate, Ultra Gauge, Spiker Mount
Gave up on making it nice.
SAS coming up
FJB
