02-03-2021, 05:11 PM
Toyota PT212-35040 Tacoma Skid Plate
Hi guys
Looking for an OEM skid plate , just for cleaner look, has anyone recently added Toyota PT212-35040 Skid Plate from a Tacoma? I found some older posts that they maybe compatible but no real follow up.
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
02-03-2021, 05:47 PM
I looked into this years ago but never pulled the trigger as the Budbuilt stuff was looking pretty good. From what I understand that will work for the non fat lip 4R with the Tacoma mounting brackets as it wasn't an option for a early 3rd gen, the 99-02 fat lip will need to use the 02 sport edition version pz327-35010 and mount brackets.
02-03-2021, 05:54 PM
Thanks for the info. I've got this new to me '96 and seems various other things I've been researching to do have details that switch with years '98/'99 etc.
Really interested as my front end is open since I purchased. All have to do is find one in Canada now.
02-03-2021, 05:58 PM
Being in Canada aswell I wish you good luck, not much to choose from up here. Best bet is eBay, and the dealer might have it still but they jumped from $120 in 2006 to $400+ in 2008, personally I like the factory steel skid, still want the budbuilt skids though badly. I think Hilux Surf had this as an option for 96-97 but now your shipping from a different continent. I'm pretty sure this aluminum peice adds onto the factory steel skid plate, the steel skid is 2 parts and covers quite well for a factory skid plate.
02-03-2021, 10:28 PM
ok thanks, don't have any skids left on mine and might not be able to mount this if I find one!
Of course creativity is the foundation many great mods.
02-04-2021, 01:28 PM
As long as you realize it doesn't do any actual skid protection... It does look good though (I had one on my '99 for a while for the looks - I wouldn't have it on there if I was going to 'used' it off road).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
