Old 02-07-2021, 01:30 AM #1
Cycleandsurf Cycleandsurf is offline
Cycleandsurf is on a distinguished road
Could this be a cracked head or gasket issue? (UV dye pic)
Used a UV dye in my oil and drive around for a couple days. I have bad oil leakage on my new-to-me ‘96 4x4 SR5. Kind of a project car for learning and looking handy in front of the old lady.
Pictured is the passenger side of what I believe to be the head gasket. It’s leaking pretty decently, and I don’t see any oil above it which would lead me to think it’s not the VCs. Same story on the driver side but not as prevalent.
From reading, external oil leaks due to head gasket failure are rare. I have both sides leaking. Could it be a cracked head? Perhaps I’m missing something altogether?
If more pictures would help, I’m happy to go crawling for them.
Cycleandsurf is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 10:25 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all
Real Name: Patrick
That is the head gasket in the photo, but it is rare to have it leak oil. Are you able to shine the UV light on the cam plugs? (Not sure if that’s the right name. They’re a round metal piece that have a cap that bolts over them. They’re recommended to get changed with the valve cover gaskets. Located on the front and rear of each head.)
2000 Limited V6 Auto E-Locker
Old 02-07-2021, 04:47 PM #3
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is just really nice 3bears is just really nice 3bears is just really nice 3bears is just really nice
i agree with Bad Luck. I think it could be related to valve cover gaskets , mostly the cam plug in the back.
2001 SR-5...bone stock ( for now) bought 12/10/20. thunder cloud metallic,
gray cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20. Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
Old 02-07-2021, 06:02 PM #4
I see, itís in the rear of the VCís. Waiting for nightfall to crawl under with the light. Iím thinking maybe I should climb above the engine to get a good angle.
gasket , head , iím , oil , side
Head Gasket issue tpostell 4th Gen T4Rs 16 10-11-2019 06:37 PM
2004 4.0 Head gasket issue? steamyfirefighter 4th Gen T4Rs 2 07-19-2018 01:13 PM
Is the head gasket an issue in the 2007 v6? jnat306bg 4th Gen T4Rs 0 03-27-2013 10:13 PM
Head Gasket/ Cracked Block. Help me? 4Running Daily 3rd gen T4Rs 3 02-14-2012 12:35 AM
Questions: head gasket and cracked exhaust manifold- 97 3RZ sgtlethargic Maintenance/Detailing 3 05-31-2008 08:39 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
