Old 02-08-2021, 03:07 AM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
No start issue
Today while out camping I left my head lights on and when I noticed I turned the head lights off it had been 20 or 30 mins and then my 4Runner wouldn’t start.
Jumper cables to a diesel truck and multiple
Starter boxes and nothing when I would turn the ignition to on. Lights, indicator lights on dash, horn, starter relay all Functioning. Figured I killed the starter some how.
New starter and the rig fired up right away. Idled 5 mins, turned off fired up again. Put tools
Away and tried to start the 4Runner and nothing same issue. Lights, horn electrical all
Works just nothing when I turn the key.
Getting it towed Home as I have AAA but I’m
Stumped what could be happening. I’ll probably go
exchange the starter again if I can’t get it to start. Also thinking maybe the plug On the starter with the two tiny wires may be an issue.
Any tips or ideas?
Thanks,
Gregg
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 09:51 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Started boxes and nothing when I would turn the heat ignition to on. Lights, indicator lights on dash, horn, starter relay all Functioning. Figured I killed the starter some how.
exchange the starter again if I can’t get it to start. Also thinking maybe the plug I. The starter with the two tiny wires may be an issue.
Any tips or ideas?
Thanks,
Gregg
The issue is most likely not your starter. You can't damage a starter by draining your battery down or leaving your key on.
Have your battery state of health checked, check/clean your grounds, and verify your starter connections are tight. If there was no click and your battery/connections check out good then I would start to diagnose the ignition switch. The ignition switch contacts can wear down over time and not send a signal to start the engine.
Old 02-08-2021, 11:22 AM #3
spartacus's Avatar
spartacus's Avatar
Check the 7.5 sta fuse also.
Old 02-08-2021, 02:48 PM #4
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
It can be the ground, starter relay, park neutral switch, or as in my case water getting in the electronics. Pull the starter fuse and see if you can jump it, that will narrow down the possibilities. Some info here;
No Power To Starter Relay
Wedgy is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 03:00 PM #5
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Here's a good reference for testing some of the potential issues with the starter. I suspect it's something in the wiring to the starter:
Toyota/Chrysler/Mitsubishi - Nippon Denso Starter Solenoid Repair
weekendclimber is offline   Reply With QuoteReply With Quote
issue , lights , mins , start , starter
Having 3.4 Hot Start Issue UnderFire 3rd gen T4Rs 11 06-29-2019 11:14 AM
Electrical Issue - Where to Start? mountain mike 3rd gen T4Rs 5 02-26-2018 11:00 AM
Cold start issue Pentium 4th Gen T4Rs 4 01-05-2016 03:52 PM
No start issue... T4RBoarder 3rd gen T4Rs 4 08-03-2015 01:52 PM
No Start Issue misstoyota517 Problems & Warranty Issues 3 03-24-2010 01:44 AM
