Old 02-09-2021, 06:27 PM #1
TraumaHawk's Avatar
TraumaHawk TraumaHawk is offline
TraumaHawk is on a distinguished road
TraumaHawk's Avatar
Installed Morimoto 2.0 LED Radio Stopped Working
Today I installed the new Morimoto LED 2.0 headlight bulbs. The low beams work but not the high beams. Contacted Morimoto and they stated I need to buy a set of resisters that plug inline with the headlight connectors. Which I'll do today.
But, the radio will not turn on though. Nothing. The 15 amp accessory fuse is good. All fuses are good. The dome light, clock, fan all work. I removed the 15 amp fuse the items stopped. Reinstalled a new 15 amp fuse and everything goes back to working fine. I checked all functions of everything in the vehicle electrical and they all work. I checked all fuses (kick panel and engine bay) and they are all good.
In addition, I replaced all fuses, disconnected negative post for 15 mins. Nothing. When the driving lights are turned on, the radio lights do not come on either.
COMO CHINGAS OFF ROAD
AAT: Senior Trail Advisor, Lower Larga 2N06X - USDA Forest Service
TraumaHawk is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 06:41 PM #2
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
Maybe check the accessory relay? I'm not exactly sure.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 11:14 AM #3
TraumaHawk's Avatar
TraumaHawk's Avatar
97' & 98' do not have a radio relay.
Old 02-10-2021, 06:10 PM #4
OEM or aftermarket radio? If aftermarket, check for fuses on the back of the radio itself.
Odd coincidence though - I wonder how they could be linked.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-11-2021, 01:28 PM #5
TraumaHawk's Avatar
TraumaHawk's Avatar
Factory radio. This weekend I will be removing the radio to see if power is at the connector to the radio. Perhaps there is a 10 amp fuse that plugs into the back of the radio like aftermarket radios use.
Old 03-03-2021, 06:56 PM #6
TraumaHawk's Avatar
TraumaHawk's Avatar
UPDATE***
Took the factory radio head unit to a factory radio service shop. The microprocessor and power supply were both dead. The technician stated "somewhere along the install of the new headlights you caused a short which produced a power surge that went into the constant low voltage power lead of the radio head unit (maintains memory). At 22 years old, your components inside are fragile and do not respond well to power surges. Your radio can not be rebuilt, parts not available. Dead. Either upgrade to aftermarket or purchase a used one off the many sites on the web. If you use another model make sure to get the amplifier as the connectors are different."
My buddy who has a 2002 4Runner just upgraded to a touchscreen double din. I took his old head unit and amp and it was plug and play.
amp , fuse , good , morimoto , work
Radio Stopped working. T4RLTD03 Engines / Suspension / Wheels / Tires / Audio / Accessories 38 02-03-2017 06:41 PM
4wd stopped working toyotaboy92 3rd gen T4Rs 7 10-17-2013 03:34 PM
4wd stopped working benedict1337 3rd gen T4Rs 0 06-02-2012 04:39 PM
Installed new radio now dashboard lights aren't working Deputy1211 3rd gen T4Rs 4 08-21-2010 11:52 PM
4wd stopped working.. MxChase 3rd gen T4Rs 2 02-04-2008 02:06 PM
