Old 02-11-2021, 10:38 AM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Something on my control arms?
I was installing my VLED hyperflash resistors last night and noticed something on the control arms and axle boots. It is on both sides but I can't seem to find a source for it. It appears like it might be grease? Any guesses as to what this might be? It definitely wasn't there prior to the lift install and the new power steering rack.
Something on my control arms?-screenshot_4-jpg  Something on my control arms?-screenshot_5-jpg
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:01 AM #2
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
That looks like the grease from a torn axle boot
Old 02-11-2021, 11:51 AM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold
JZiggy's Avatar
I dunno, looks like of like queso to me. Get some tortilla chips and test it out.
Definitely grease getting back the CV boot via a bad seal or a crack in the boot.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 12:21 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all
Real Name: Patrick
That's from your axle shafts. It's common for that to happen after a lift with old axles. Your old axles were used to a certain working angle then you lifted your 4Runner and changed that angle and now the boots are leaking grease.
2000 Limited V6 Auto E-Locker
Old 02-11-2021, 12:44 PM #5
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
Welcome to the world of a lifted vehicle. Suspension and steering parts won't last as long now.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 02-11-2021, 02:48 PM #6
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Torn CV boot, my dude!
Just dealt with it myself.
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 02:56 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
Whether you decide to reboot or replace your axles, this video will help you out.
Old 02-11-2021, 03:18 PM #8
spartacus's Avatar
spartacus spartacus is online now
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
Here is a good writeup.
Reboot your CV axles - Toyota 4Runner Forum - Largest 4Runner Forum
spartacus is online now   Reply With QuoteReply With Quote
Old 02-12-2021, 01:36 AM #9
Any ballpark estimates on what I should expect to pay a shop? Looks like a fun job but I have literally no time to do mechanical work before May. It looks like the OEM axles are ~ $400 each from what I'm finding. The front diff seal needs replaced as well as the lower ball joints, so I'll just take it in and get everyone taken care of at once.
99' SR5 HRU
Old 02-12-2021, 02:47 AM #10
Fiffa's Avatar
Fiffa's Avatar
I got my OEM reman axles for about $185 a piece on the Toyota parts site. The seals are about $10 (which reminds me that I need to pick up mine, lol). The axles I removed I plan to rebuild when I get a minute... and some CVJ extended boots.
IG: get_lost_fiffa
Old 02-12-2021, 03:51 AM #11
spartacus's Avatar
spartacus's Avatar
cvj axles are pretty reputable in the off road community out here
CVJ Axles - CV Axles & Steering Racks for all your needs
Old 02-12-2021, 12:10 PM #12
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 has a spectacular aura about cblock406 has a spectacular aura about
cblock406's Avatar
Also consider a diff drop if you don't have one already.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 07:51 PM #13
I've got the toytec diff drop on there now, but I guess it wasn't going to save my 22-year-old boots, lol.
I'm wondering if I'm going to have the whole front end apart to do the control arms and LBJ's plus diff seal and axles, if there is anything else that I should try to get done at the same time?
99' SR5 HRU
Old 02-12-2021, 08:20 PM #14
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy has a spectacular aura about RandyBobandy has a spectacular aura about RandyBobandy has a spectacular aura about
I hate to be the bearer of bad news but that’s horse semen, your ride is totaled.
RandyBobandy is offline   Reply With QuoteReply With Quote
arms , control , grease , power , steering
FREEDOM Offroad Control Arms - Under $350 Tubular Upper Arms from Battle Born! Battle Born Offroad Suspension 26 07-03-2020 02:39 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
New Control Arms daka320 4th Gen T4Rs 14 04-09-2016 10:11 PM
Control arms baddkarmaracing 5th gen T4Rs 10 07-18-2015 08:00 AM
Control Arms, Yes or No? Dkon82 4th Gen T4Rs 20 11-08-2011 07:36 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
