Old 02-13-2021, 01:37 PM #1
Big-Boy Big-Boy is offline
Big-Boy is on a distinguished road
Hood latch adjustment?
Anyone have some advice on hood or hood latch adjustment? I recently put on a sport hood with the hood scoop. My factory hood used to have a lot of trouble closing as well. I'd really have to slam it shut. Not just let it drop, but put some extra down force behind it.
Now that I've got a new hood and new grill in place I don't want to slam them. I did let it drop from pretty much full height and still can't get the thing to latch. The safety latch will hook but not the hood latch. I did play with the little rubber stops and adjusted them all of the way in so they were out of the way, didn't seem to be the issue. In fact the hood was setting too low at that point, but still wouldn't latch.
Maybe I just need a new latch all together? Any thoughts would be appreciated!
Big-Boy is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 01:59 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
The only adjustment for the latch is the 3 mounting bolts for the latch, loosen and adjust as needed. Ofcourse the hood can be adjusted aswell if needed at the same time.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 02:09 PM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Try cleaning the latch with brake cleaner and then lubing it up with a spray silicone or dry graphite. Then take a screwdriver and use that as the catch on the hood to work the latch as you lube it. That worked well for my latch and it's been fine since.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 02:16 PM #4
spartacus's Avatar
spartacus's Avatar
[QUOTE=Big-Boy;3604152]Anyone have some advice on hood or hood latch adjustment? I recently put on a sport hood with the hood scoop. My factory hood used to have a lot of trouble closing as well. I'd really have to slam it shut. Not just let it drop, but put some extra down force behind it.
Maybe I just need a new latch all together? Any thoughts would be appreciated![/QUOT
lubricating the mechanism and pusing the right side of the spring down has worked for some.
Hood latch adjustment?-screenshot_2021-02-13-11-10-51-jpg
Old 02-16-2021, 02:04 PM #5
Start with lubing the latch and adjusting the the hood instead of the latch, if possible. The latch has the 'centering bolts' as shown in the above procedure. You might even be able to bend the latch loop a bit to line it up.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-16-2021, 04:54 PM #6
nissanh nissanh is offline
I didn't install a new hood, but I notice, it is vibrating when driving. I took the latch out and filed 3 holes vertically so I can move the latch up or down. Did the adjustment and was able to get the hood to stay firm.
Old 02-18-2021, 01:19 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
There's a couple rubber bumpers on the top of the radiator support on either side that you can twist up or down to adjust how pressure is on the hood to keep it from vibrating.
adjustment , hood , latch , put , slam
Hatch Rattle, Latch Adjustment? Colorado S14 5th gen T4Rs 26 04-04-2024 09:39 AM
How to?? Hood Latch removal. (Plastic pull latch lower driver side) Stewart 5th gen T4Rs 5 01-27-2021 12:25 PM
07 hood suddenly won't close all the way. Hood latch issue. Help! depth 4th Gen T4Rs 0 08-30-2017 09:56 PM
Hood latch differences. Fitting a sport hood on a Limited 4eigner 3rd gen T4Rs 15 10-26-2016 05:31 PM
