Old 02-13-2021, 07:30 PM #1
eastsideride's Avatar
eastsideride eastsideride is offline
Real Name: Meeeeech
eastsideride is on a distinguished road
Real Name: Meeeeech
Outer CV boots - repair/replace?
Hey all,
I read a lot of conversation about inner CV boots, but not a ton about outer CV boots... so here I am.
I got stuck in some snow the other day and while in 4WD I heard a loud clunk/pop when trying to get out. The front wheels were not spinning but the back wheels were since the snow was holding the axle up. I'm thinking the pressure made the passenger side CV pop.
Checking it today, I heard it pop while turning to back out of my parking spot. Driving around to see if something was broken I saw the boot clamp on the ground and just knew it was CV related. So anyways, outer passenger boot is ripped.
Now, I've already replaced inner boots before as I installed CVJ boots and stretched them out to prevent tears from being lifted. But my question is, should I just replace the outer boot or would the CV be damaged hence the popping? I just want to make sure I order the right thing to fix this thing up this week.
Cheers
eastsideride is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 12:04 PM #2
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
I think you really just need to inspect the joint to be able to tell what kinda of damage has occurred.
I hope you have somewhere warm to work if weather in wisconsion is anything like it is hear in michigan.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 02:19 PM #3
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
i definitely thought i had a busted cv with a lot of pops and clicks in 4wd.
Found a pair of old OEs on craigslist for 40 bucks to clean and reboot.
After i swapped them in i decided to open up the originals to see what failed and they were totally fine just low on grease. Deep cleaned looking for cracks or failures but found none so i regreased, rebooted and now have them as my trail spares.
so yeah, i'd pull em apart and clean the hell out of them then if all is good, reboot and carry on.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
back , boot , boots , outer , wheels
Replace Axles with OEM Boots or Extended Boots Rock_Rat 3rd gen T4Rs 79 11-10-2020 06:44 PM
Can outer tie rod end boots be replaced? Qyota 3rd gen T4Rs 10 08-04-2014 03:52 PM
Anyone Used Energy Suspension Outer TRE Boots? TRDFerguson Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-13-2014 02:11 PM
Do I NEED to Replace Outer Tie Rod? Kanger328 3rd gen T4Rs 2 05-21-2013 08:28 PM
