Originally Posted by willie2323
Hello All,
My 99 Runner is high enough but it rides very harsh compared to when it was new. What suggestions can be made to get the ride back to newish?
thanx all in advance for your suggestions.
cheers,
willie
as long as your not running any extra weight?
I have been running this setup with some OME rear springs for about 6 months and it's awsome.
Bilstein 0-2.3" 6112+5160 Lift Kit for 1996-2002 Toyota 4Runner
I would pair it with some stock Toyota springs in the rear.
I run mine with 1" lift in the front and 2" springs in the rear but... you can totally set it up with 0 lift as well.
for the rear toyota spring this one is fine
4823135200 SPRING, COIL, REAR, RH/LH
48231-35200 - Genuine Toyota SPRING, COIL, REAR)
do this and it should ride like a new truck. I would also say tires can make a huge difference. I used to run load range D tires but have swapped back to load range C and it also provides a much cushier ride on the road.
