Old 02-15-2021, 01:29 AM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Filler Panel Screw
I’m finally installing headlight filler panels (bought it without them), and I need the fasteners for both sides. For the outside I’m gonna get these. Does anybody know why it’s two separate part numbers?
For the inside I went to Ace today to try and get the right screw, but it looks like it’s not actually a screw…
I found this diagram,
Which led me to this:
Will this do? It says screw, but the hole didn’t look like it had any threads so I’m confused. Any help is appreciated. Thanks
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 02:51 AM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
90159-50316 is a screw with a large flange head that screws into a plastic retainer 90467-12040, 90159-x should be easily substituted, the left and right outer retainers appear side specific in the diagram and would need to be correct, I didn't remove the outer part so can't help further.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 11:42 AM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
what I like about this site is the pictures.
they are side specific of course... mirror images of each other
5252235030 Toyota RETAINER, FRONT BUMPER FILLER, NO.2, Price: 2.91$, Weight: 0.001kg - PartSouq Auto Parts Around the World
5252335030 Toyota RETAINER, FRONT BUMPER FILLER, NO.3, Price: 2.72$, Weight: 0.002kg - PartSouq Auto Parts Around the World
the screw
9015950316 Toyota SCREW, W/WASHER, Price: 0.5$, Weight: 0.005kg - PartSouq Auto Parts Around the World
you can use the generic
https :// partsouq.com/en/search/all?q=part number here
if you know the part number, they don't have all the parts in pict format.
Old 02-15-2021, 01:37 PM #4
5VZ-FE's Avatar
5VZ-FE's Avatar
Ok, thanks. Based on this it looks like I got the right stuff.
Old 02-16-2021, 10:31 AM #5
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
I just ran some random screws I had laying around through them. Since they go into plastic the threading doesnt have to be exact.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
filler , it’s , i’m , led , screw
3rd Gen. 4runner Filler Panel Lights SCHUNTER1969 3rd gen T4Rs 8 02-10-2019 11:12 PM
SRQ Fabrications Filler Panel Release SRQ-Runner 3rd gen T4Rs 0 04-05-2018 08:04 PM
New filler panel light bar design! SRQ-Runner 3rd gen T4Rs 75 04-02-2018 09:21 PM
Anyone swapped grille filler panel for LED's? overfedfish 3rd gen T4Rs 8 09-10-2017 10:05 AM
WTB: 3rd gen panel hole filler plate in oak dgoll75 Want to Buy/Trade 2 04-06-2014 12:03 PM
