Old 02-18-2021, 12:40 AM #16
giguchan's Avatar
giguchan giguchan is offline
giguchan is on a distinguished road
giguchan's Avatar
Originally Posted by phattyduck View Post
Toyota normally calls them VSV = vacuum switching valve... but same thing.
On the '96-'00 non-Limited, the only actuator is the vacuum ADD actuator on the front diff. A switch on the transfer case activates the relay in the passenger footwell, which powers the VSV's to swap vacuum direction on the ADD actuator. When the ADD actuator moves, it hits a switch that turns on the dash light.
Since you hear the ADD relay working, the transfer case portion of the system is working. Check the ADD vacuum lines. Check the VSVs themselves. If 4WD *feels* engaged but the light is off, it could just be the indicator switch on the front diff.
Also, things could just be sticky due to non-use. The system should be actuated at least 1 a month. Toyota says 5-10 miles every month. Just pick a straight section of road and engage 4WD every so often. I just do a couple of side streets every month (put it in 4WD at a stop light/sign - then disengage next time I have to turn).
Thanks again Charlie
I am indeed guilty of not exercising the system as i should... However i have done it in the past but not nearly as what is recommended.I'll start tomorrow looking things over. Oh.. 4WD does not feel engaged due to fishtailing all over the place.. when it was working that day all i had to do was tap on the throttle and all 4 Duratracs pulled me where i wanted to go.. when it stopped- so did i!
Again thank you.
TRD Exhaust, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade,LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 190K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 12:52 AM #17
giguchan's Avatar
giguchan's Avatar
**An Update Not a big one but one just the same.
I crawled under the truck and check for everything
that i was advised to from Members on this board.I
could not find any wiring issues nor any vacuum hoses
that messed up either. I had to bring the truck in for it's
Oil change and while there i asked them to have a look.
The dealer struck out also.I received a lot of excuses from the Service advisor is all i got. The only excuse i am buying is that while i was there on a Saturday GET EM IN GET EM OUT! they could not spare one tech to actually DO any trouble shooting.. What is needed is a Tech who works on these old trucks..
Luckily i think i found one. More next time.
Currently 190K
Cheers
Old 03-12-2021, 03:43 PM #18
giguchan's Avatar
giguchan's Avatar
Another quick update
Hey all,
It has been determined that the Front diff actuator is indeed bad.
Has anyone had any success in replacing this(with limited tools and know how) or is this better left to the Dealer? I was quoted out the door $800 minus the diag service Fee.The Part itself isn't too bad@$375.
Thanks.
Currently 190K
Cheers
Old 03-12-2021, 04:13 PM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all
Real Name: Patrick
Originally Posted by giguchan View Post
Hey all,
Thanks.
The worst part will be dropping the front diff. Here's a video of the front diff removal: https://www.youtube.com/watch?v=w_gPiDvh9v4
2000 Limited V6 Auto E-Locker
Old 03-12-2021, 04:48 PM #20
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
I think you can replace the actuator with the diff in the truck...
'16 Honda Odyssey
Old 03-12-2021, 06:32 PM #21
Real Name: Patrick
Real Name: Patrick
I wasn't sure if there was enough room to pull the actuator out all the way for the shift fork (probably the wrong word but the part that moves the engagement mechanism in the ADD). If there is then that will save the OP a ton of work!
Old 03-13-2021, 09:43 PM #22
giguchan's Avatar
giguchan's Avatar
The Part has been ordered. I will indeed look into if it can be removed/installed without dropping the Front Diff.
That would explain the 4 hrs Labor.
Thanks Guys.
Currently 190K
Cheers
Old 03-19-2021, 11:26 PM #23
fullmoonguru fullmoonguru is offline
fullmoonguru is on a distinguished road
+1 on the vacuum lines.
fullmoonguru is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 01:29 AM #24
giguchan's Avatar
giguchan's Avatar
I wish it was a few Vac Lines.... I aint got that kinda luck...
Currently 190K
Cheers
4wd , back , light , min , work
Heater issues/cold air issues xcalbr2 5th gen T4Rs 5 11-20-2020 01:02 PM
Help needed with brake issues (multiple issues) Terminator03 4th Gen T4Rs 11 10-17-2018 10:26 PM
93 4Runner radio issues and door actuator issues. 128keaton Classic T4Rs 2 05-10-2015 10:11 PM
Issues, lots of Issues... WillK 4th Gen T4Rs 18 09-10-2013 09:34 PM
rear driveshaft issues.....Big issues CRIVRUNNER Classic T4Rs 9 01-10-2011 02:04 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
