Old 02-18-2021, 05:13 PM #16
CT135 CT135 is offline
CT135 will become famous soon enough
Originally Posted by T4topher View Post
How big of a piece of 18 gauge did you get for both pieces?
2 sheets of 16x24. Had plenty of extra space in cause I messed up my original cut and needed some to patch. Luckily I kept it all in one chunk.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
CT135 is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 04:53 PM #17
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Finally just finished. How did you mount the modules that were attached to the firewall itself? I got all the wiring hooked back up except those 2 modules, was thinking about just using some zip ties but wanted to see if there was a better solution?
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 03:24 PM #18
Mine were still able to clip back on. It took a generous smack but they stayed when I hit them. The bottom isn't hooked but the top was able to latch. It doesn't rattle off road or anything so I'm leaving it as is. Zip ties would be an easy fix though if yours isn't latching.
Old 04-15-2021, 05:13 PM #19
T4topher's Avatar
T4topher's Avatar
All the clips and everything still pops back into their original locations, but on the driver side there is the 4wd module (black box) which had a 10mm bolt attaching it to the firewall. That attachment is no longer there after cutting.. I think passenger side has something similar as well.
Old 04-16-2021, 08:40 AM #20
Oh ok I know what you’re talking about. Passenger one I just shoved in and closed it up without bolting it in. Driver side there was one available spot that I bolted the 4WD module in. It’s sitting at a weird sideways angle but secure.
I’d say zip tire most of it together and it’ll all stay tight and you’ll be good to go. Make sure you test 4WD and locker. I was nervous after all of that cutting and pulling wires around.
Old 07-26-2021, 06:45 PM #21
Greeny's Avatar
Greeny Greeny is offline
Real Name: Riley
Greeny is on a distinguished road
Greeny's Avatar
Real Name: Riley
Firewall tub on my 97 limited- pictures and mini write up
Nicely done, looks good!
Just finished mine off recently as well, only have good photos of the passenger side but it looks very similar to yours. I started on the driver side with what I eventually realized was not a big enough cut, so I ended up still using a BFH to open up the hole and make a little more clearance. When it came to doing the other side I thought it best to just go big from the get go. Also cut the fenders and emptied out the inside of the flares.
Still need spacers to clear the frame, but no rubbing up front in my last trip, and i was doing bigger, more challanging stuff than I ever did on 33's. Well worth the time and effort!
Firewall tub on my 97 limited- pictures and mini write up-image1-2-jpg  Firewall tub on my 97 limited- pictures and mini write up-image3-2-jpg  Firewall tub on my 97 limited- pictures and mini write up-image11-jpeg  Firewall tub on my 97 limited- pictures and mini write up-image12-jpeg  Firewall tub on my 97 limited- pictures and mini write up-image13-jpeg
Greeny is offline   Reply With QuoteReply With Quote
Old 11-18-2021, 12:35 AM #22
t4r-4-mtb t4r-4-mtb is offline
t4r-4-mtb is on a distinguished road
Wow, awesome job! I don't have tools or experience and I need this done on my '02 because I get a ton of rubbing with my 35s right now. Hoping to find someone in the SF Bay Area to do it for me.
2002 Thunder Cloud T4R SR5 Sport | Factory Center Lock | ARB Front & Rear Lockers | ARB Compressor | 4.88:1 Gear Ratio Front & Rear | Lift: 1" Body, 3" Front 3.25" Rear | King 12" travel coilovers w/600 lbs/in springs | SPC Upper Control Arms | Fuel SHOK Wheels Satin Black | Falken Wildpeak M/T 35x12.5 17 | Tundra Big Brake Conversion | Sherpa/Rocky Mountain Roof Rack | All Pro Apex Off Road Front Bumper | CBI Swingout Rear Bumper | CBI Dual Jerry Can Mount | Dual Wavian 5 Gallon Jerry Cans | 4xInnovations Sliders
t4r-4-mtb is offline   Reply With QuoteReply With Quote
fender , flares , inside , limited , tub
Replacing Valve Cover Gaskets - A True Write Up - **PICTURES** ramonortiz55 3rd gen T4Rs 207 01-08-2023 11:08 PM
Loose Shifter? - Replace your shifter bushings! - Write up with pictures ramonortiz55 3rd gen T4Rs 34 11-13-2021 07:59 PM
URGENT: Looking for a good Write-Up/DIY with pictures to change Rack and Pinion Unit! TheFriZ 3rd gen T4Rs 23 07-08-2014 12:25 PM
Running Wire Through the Firewall/Rubber Gasket in Firewall ts9790147 4th Gen T4Rs 4 04-06-2010 05:39 PM
1999 limited 5vz-fe engine timing belt write up shootmymime Maintenance/Detailing 1 09-05-2008 09:16 AM
