Old 02-17-2021, 07:59 PM #16
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Here you go, and you don't even need to leave the house. My dealer always throws in a paper covered aluminum washer, although I'm sure I payed for it somehow. Gotta be careful with "more" claimed filtration, if it filters to well you might lose oil pressure or have delayed oil pressure on startup, Toyotas/Japan vehicles have very low oil pressure at idle, or if equipped it could bypass the filter, some filters also have cheap anti drain back valves again making for slow build up of oil pressure, some have cold weather/clogged filter bypasses, and some cheap filters use plastic cages inside to hold the filter media, but I'm sure most quality filters mentioned work just as good as OEM. You know what they say, your engine gets the most wear at startup, and considering what Toyota has at stake I assume they made the best choices for our application through R&D using the best materials.
Amazon.com: Genuine Toyota 90915-YZZD3 Oil Filter: Automotive
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 08:26 PM #17
Originally Posted by thennen View Post
After more thought, if a dealership is nearby, I can't see why you would try to pursue aftermarket options, unless it's convenience. At best you're saving $3 per filter by going aftermarket, and the filter is good for at least 5000 miles, so the savings are negligible. The only thing an aftermarket filter could offer is filtration that is BETTER than what Toyota recommends. So your gain is what?
The OEM filters also use a real o-ring which is much better at sealing and the o-ring comes pre-lubed. For those reasons alone, it is worth it!
I'd still be willing to use a Purolator or Bosch oil filter, but my two Toyotas can use the same filter, so I just keep the D3 filter in stock on the garage...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-17-2021, 08:49 PM #18
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
My local Walmart has the OEM Filters in stock which is nice to know. I have been using STP Filters and they have been great.
2000 4Runner Limited 4x4 V6
Old 02-18-2021, 03:20 AM #19
josh3rd josh3rd is offline
Real Name: Josh
josh3rd is on a distinguished road
Real Name: Josh
never thought about it that way malcom. thank you
josh3rd is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 03:21 AM #20
Real Name: Josh
Real Name: Josh
To everyone who responded, I truly and greatly appreciate it. Thanks fellas
Old 02-18-2021, 04:28 PM #21
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Crazy bulk savings on YZZD3 at Bezos'
Free shipping on either option
QTY 1 $8.68
-or-
QTY 10 $44.00
4runner , filter , fit , fyi , oil
FS: V6 4runner/Tacoma/Tundra engine air filter + cabin air filter $15 - North NJ jsun_2k For Sale: T4R Items 5 08-15-2019 12:53 PM
2003-2009 4Runner Stuff. Sport Wheel, OEM Bug Deflector, Oil Filter, Cabin Air filter 00HiluxSurfLTD For Sale: T4R Items 2 06-18-2014 01:59 PM
5VZFE Bosch Premium Oil Filter Parts Compatibility (and using an Oversized filter) nobb 3rd gen T4Rs 6 11-20-2013 03:07 AM
FS: clear corners, air raid drop in filter, oil and oil filter Atreyus For Sale: T4R Items 4 08-20-2012 10:28 PM
AKEBONO front&rear pads, air filter and cabin filter MoJoe Classifieds - buy & sell (no commercial ads please) 6 04-26-2011 09:09 AM
