Old 02-17-2021, 02:37 PM #1
Jayc97 Jayc97 is offline
Jayc97 is on a distinguished road
P0301 Issue
How's it going guys, I've been searching around for topics on my issue and figured I've post one myself regarding code p0301 that's causing my CEL to come on. I've been dealing with is code since last summer, July to be exact, I've replaced fuel injectors, wires, spark plugs, and coil packs all oem and ive noticed that the CEL will go away from about 2/3 weeks then it will re appear. It simply turns on, doesn't flash or anything. The ideal feels fine, no indications of stalling or anything like that.
Would anyone have any other suggestions on what it could be? I've read on other posts it could be a head gasket issue or even the actual cylinder head. Any feed back helps, as I would like to keep my 97 4runner as long as I can. Thank you in advance for any help/info!
Jayc97 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 02:54 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Did that include checking all the connector connections and vacuum connector connections?
Old 02-17-2021, 03:25 PM #3
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Verify all connectors you messed with don't have broken tabs. If they do replace those for secure electrical signals. Compression check. Leak down test. That's where I'd start. If all passes you can mess with u.v. dye through the system and see if the dye stains anything using a black light. All in all all 3 tests will run you $150 in supplies assuming you own an air compressor. Shops near me charge $100/hr with a 1 hr minimum...so 50 bucks more you got unlimited ability to repeat all 3 tests at any point on any vehicle....yours, families, and friends.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
cel , code , head , issue , p0301
I Got a MISFIRE P0301 Garcia9876 3rd gen T4Rs 15 02-01-2020 09:58 PM
P0301 when hot Brian1973 3rd gen T4Rs 8 07-28-2017 10:52 PM
Pending P0301? thegipper 3rd gen T4Rs 4 04-17-2017 07:47 PM
P0301 code snowninja 3rd gen T4Rs 15 12-13-2012 01:24 AM
