I wouldn't try to seal it off, that's not a great solution, you can remove the glass if inoperable to clean drains, find out where it's leaking, for me with was a rear left drain tube that popped off the tray, I just removed the rear grab handle and rear 1/4 trim pryed the headliner don't gently and used a long pair of pliers and reattached. The headliner backer is water proof so a leak could show up anywhere depending on the angle you park.
