Old 02-19-2021, 02:00 AM #1
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Sandblasting Opinions Requested
I have a painted valve cover from another car that I'm going to media blast myself. If anyone has any experience, would love some input:
1) The Valve Cover is Magnesium
2) My plan is to use Soda (medium grade) for the cover inside and outside. If that doesn't work, I'm going to use medium Glass bead for the outside and might leave the inside as is.
3) If I can't get rid of the paint on the outside with Soda, I will switch to Glass Bead, with Aluminum Oxide as a final last resort.
4) I intend to use Zinc Chromate primer with a flat black wrinkle coat spray paint in the end for the outside. I don't plan to paint the inside.
There are NO oil baffles on the valve covers, it's just a single piece.
My one concern is using glass beads on the inside and possibly having some "embedded" that might work itself loose later one (since Mg is so soft?). As I understand, Soda pretty much disintegrates/washes off.
Can I blast the edges that the gaskets sit inside or would that risk creating leaks? Those gasket seats are also painted the the paint is bubbling in various places in various degrees already.
Does this sound about right or would you have other experienced suggestions?
Thanks!
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 09:59 AM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
For what purpose? Just use a stripper - they make gentle/noncaustic stuff for metals like magnesium.
Old 02-19-2021, 10:19 AM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Honestly would just use a stripper, such as Citru-Strip.
The valve covers are just oily and grimey right?
Soak them in citru-strip over night and hit them with a pressure washer. They will look like new
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 11:30 AM #4
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
I powder coated the 5vz covers with a wrinkle red. Ended up looking nice, if a little like Honda colors. Because these are baffled I cleaned them by hand first with a mix of a dremel and just scotch bright.
My experiences sand blasting other things is just to mask off any surfaces you dont want hit with painters tape. On tip for masking is to us the flat side of a razor to pull over the painters tape at the edge you want to cut it at. Kinda like when you are using a crayon to see indented writing on a piece of paper. That will make a nice clean edge.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 11:33 AM #5
I bead blasted my valve covers and intake when I rebuilt the engine.
Old 02-19-2021, 02:36 PM #6
lockedlex's Avatar
lockedlex's Avatar
Thanks, so +1 for bead blasting.
I've already tried the paint stripper option, but it's not working. It's painted from the factory and just doesn't seem to want to come off.
So it's OK to blast the tunnel that the valve cover gaskets sits on to remove paint there? No chance of it leaking if I'm bead blasting it? Should I maybe put a thin layer of RTV to be safe?
Old 02-19-2021, 03:01 PM #7
dmppdx dmppdx is offline
dmppdx is on a distinguished road
Often, the paint used for things like valve covers and other automotive parts won't come off using normal paint stripper. If you get some Aircraft Stripper, that normally works since that normally dissolves any paint or epoxy, but I think its way more toxic so use more care with it.
dmppdx is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 03:13 PM #8
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Gasket seat is painted? Weird. I've blasted tire beads with glass and they didn't leak after so wouldn't think it'd be a problem to blast. Yes, would avoid blasting inside with anything harder than soda or walnut shells. If DCM stripper won't take it off I doubt those will though.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 05:02 PM #9
lockedlex's Avatar
lockedlex's Avatar
Yeah, already tried aircraft stripper, (without DCM since it doesn't seem readily available in Cali) and it basically didn't work, plus was really concerned about the toxicity, smell (even with PPE on).
Old 02-19-2021, 05:08 PM #10
lockedlex's Avatar
lockedlex's Avatar
Yes, I'm not a fan of what they did. It was painted from the factory, here's an example. Last time I opened it up, about 8 years ago, It was already peeling and I took a light sanding block but didn't really go to far into the seat/groove.
Good to know that beadblasting should be OK if needed. My plan is to try with Soda first... see how far that gets me for the outside and then go harsher if needed.. all the way to maybe an alum oxide or black beauty (?).
For the inside, I might just stop at "good enough" for fear of getting anything embedded, possibly messing up the Mg (?), or ripping of parts of the gasket groove seat. Worst case, I can just RTV it with whatever paint might be left.
Sandblasting Opinions Requested-gasket-jpg
Old 02-19-2021, 09:09 PM #11
My VCs were aluminum. They cleaned up nice.
Only thing I’d do different is id soak them in acetone for a few weeks to remove the oil coking in the baffling.
I clear coated the VC’s. They eventually yellowed.
cover , glass , inside , paint , soda
Opinions requested - ladder with stock roof rack, yay or nay? Karzir 5th gen T4Rs 20 05-02-2016 12:29 PM
Sandblasting wheels T4Rscott 3rd gen T4Rs 2 05-17-2015 09:38 PM
Who needs cheep sandblasting. You pay shipping. shootmymime Off Topic 14 11-18-2013 10:27 AM
Windshield - Heavy Sandblasting at 19k 4C4Runner 5th gen T4Rs 26 11-27-2011 03:21 AM
Sandblasting Dynamat? kylebacc General Discussions 10 06-10-2010 09:38 AM
