My same thought exactly!
Why? Because I dislike wasted spark design with 3 coil packs. But mainly because I can.
Converting to true COP is difficult, as there are only 3 ignition timing signals going from the ECU. It would be necessary to split those 3 signals to 6 signals firing twice less often, the split decision would have to be made using some 3rd party circuit fed with the signal from camshaft sensor.
BUT
Converting to wasted COP - i.e. 6 single COPs but still fired simultaneously in pairs should be fairly easy. There are two possible ways of doing that.
Using 6 2-pin COPs and connecting the pairs in parallel to the OEM ignition module OR
ditching the ignition module, ale using 6 4-pin COPs from Lexus, which give the IGF return signal back to the ECU.
It's only theory for now, but I'm eager to try that in practice really soon. I'm swapping my 3.slow to 5VZ-FE, so I'll have a new engine to play with
