Old 02-24-2021, 07:59 PM #16
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I'll give the master cylinder bleeding a shot, as well as new brake bleeders in the back and with the engine on this time. Thanks for the suggestion guys!
2000 4Runner Limited 4x4 V6
Old 02-25-2021, 12:42 AM #17
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
I have not bled a 3rd gen. With all other vehicles I start with a gravity bleed. Let the system push air out by itself. Keep the master cylinder topped off. This is a simple and effective start to bleeding the brakes. It takes some patience and a large bottle of Dot3.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 09:10 AM #18
bdjcl bdjcl is offline
bdjcl is on a distinguished road
Originally Posted by T4topher View Post
Could get speed bleeders, makes brake bleeding a one person job.
I cannot recommend this enough. I got so fed up with bleeding my system after a rear drum brake job that I bought 4 speed bleeders, installed them all around and the system bled like a dream.
Install speed bleeder, attach little hose to it, open bleeder, pump brake pedal, top off reservoir, repeat, close bleeder.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 01:50 PM #19
That's great, but it will make your master cylinder go bad if it was on the edge (poor previous maintenance, basically). Just be prepared for that eventuality.
I have also use a vacuum bleeder with varying levels of success.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-25-2021, 02:29 PM #20
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Maybe I misread/misinterpreted but speed bleeders make your master cylinder go bad?
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 02:48 PM #21
Not exactly. If your master cylinder is wearing out (damaged bore), the damage first appears farther 'down' the bore. Either a two-man bleeding procedure or using speed bleeders will use the whole range of master cylinder travel, which damages the seals and will require replacement of the master cylinder.
Pressure and vacuum bleeders can be used, and you won't have a leaky master cylinder right after a bleeding.
Basically, if your master cylinder was close to failing already, the bleeding procedure will take it out. Of course, you don't know if it is "about" to fail - but you will find out after the bleeding! Just be prepared. Oh, and that's the reason why you should be regularly bleeding the brakes (ever 2-3 years) - to keep the master cylinder bore clean and corrosion/pitting free.
Old 02-25-2021, 08:37 PM #22
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
@phattyduck is spot on with hidden corrosion being such a problem in brake systems. I can’t remember how many times I have seen brake systems fail internally due to corrosion from dirty fluid. With brake fluid being hygroscopic in nature, it is optimal to change brake fluid in the South here every other year.
I also don’t let soft brake lines stay on an automobile for more than twenty years; they can last for only so long.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 01:54 PM #23
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Originally Posted by Malcolm99 View Post
The best thing on these trucks for solid brakes is a perfectly set up e-brake cable, bell crank and brake shoes as per the FSM. You can remove the bleeder completely and clean out the orifice if its not cooperating. I'm on original drums and calipers, bigger tires, and it stops like a brand new SUV with a solid pedal, everyone one of these trucks I've seen with a soft pedal was because of a rear drum brake issue.
This has been the overwhelming consensus here for people who have TBU issues.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 03:43 PM #24
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
And to be honest the TBU is completely unessessary unless you're hauling a heavy trailer or rocking 35" tires, it's ALL about the rear drum brake set up and adjustments, if your off by 1mm drum to shoe clearance for each shoe, 4mm total, you get soft brakes and/or excessive brake travel, and then you are over using the front brakes and they warp. You must pull the plugs in the backing plate and measure and adjust shoe to drum clearance after the ebrake and bell crank clearance is set up
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 07:20 PM #25
yep, had this issue too. I didn't have the shoes adjusted out nearly far enough when first put the drums back on.
bled , bleed , brake , pedal , rear
Brake bleed question DannyKhaKha 4th Gen T4Rs 2 09-11-2019 07:11 AM
Brake bleeder - one man bleed mavrick1903 4th Gen T4Rs 0 08-06-2017 06:32 PM
Brake Bleed DC Dude Maintenance/Detailing 18 08-29-2010 07:59 PM
Brake line bleed ksroqclimber 3rd gen T4Rs 3 08-09-2010 05:29 PM
Shouldnt any brake job also bleed the brake lines? Muti007 3rd gen T4Rs 10 04-23-2010 10:39 AM
