Old 03-06-2021, 03:25 PM #16
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Someone on Facebook is recommending throttle cable/kickdown cable adjustment or transmission shift solenoid. I’ll try to get the cable adjusted and see what happens if no change then I’ll check out the solenoids, if anyone has a part number that would help tremendously..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 04:23 PM #17
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I remember when my throttle cable was loose asf and tightening it improved the gas pedal immediately.
Another thing is to check all 4 brakes for seized calipers and pistons. A seized caliper would slow down the vehicle due to heavy drag - this happened to my Civic and caught the problem to be a seized rear caliper.
2000 4Runner Limited 4x4 V6
Old 03-06-2021, 07:22 PM #18
T4topher's Avatar
T4topher's Avatar
I did previously adjust my cables but Im wondering if I adjusted the kickdown incorrectly. I definitely need a new throttle cable as it’s pretty much maxed out and it’s still a bit loose.. I just installed new oem tundra calipers/rotors/pads, rebuilt them myself and they work flawlessly. Not sure about the drums though.
Old 03-08-2021, 01:15 PM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The "kickdown cable" only adjusts transmission hydraulic line pressure and does not change when the transmission will shift. If that cable is too tight you will have very hard shifts.
Old 03-08-2021, 04:24 PM #20
T4topher's Avatar
T4topher's Avatar
Good to know, I’ll try messing with it a bit tonight and see if it changes at all. Thank you everyone for all the suggestions and insight, much appreciated!
Old 03-08-2021, 07:16 PM #21
I think you will need a new throttle cable, not the throttle body unit.
Old 03-08-2021, 09:26 PM #22
T4topher's Avatar
T4topher's Avatar
Well just tried adjusting the cables around a bit and makes no difference at all. I think I’m gunna try to see if it still happens if I lock it into L vs 2 vs D.. that should really tell me wether it’s the transmission or not I’m thinking.
Edit: seems like it only happens in 2 and D not in L so I’m now suspecting the shift solenoid. Finally a potential clue!! Lol.. Do I replace all 3 or try to figure out which is the one that is causing the trouble?
Old 03-09-2021, 09:48 AM #23
Real Name: Patrick
Real Name: Patrick
If it was me, I would replace all the solenoids and install a transgo shift kit when I had the pan off. I'd also use a felpro gasket for the trans pan instead of the sealant. That stuff is a bear to get off.
Old 03-10-2021, 10:04 AM #24
Have any of you with the problem ever watched your LTFT when it happens?
How old are your O2 sensors?
Old 03-10-2021, 12:41 PM #25
T4topher's Avatar
T4topher's Avatar
Haven’t watched LTFT but my 02 sensors are practically brand new. Going to try my transmission solenoids and maybe the transgo kit.
Seems like there are two shift solenoids and one over drive solenoid, found the number for the shift solenoids (180$ each.. ouch) but can’t find the number for the overdrive solenoid.. thinking about doing the transgo kit, I think there are two kits for our transmission (sk340 vs 340hd2) seems like the sk340 might be less race car like but everyone that I’ve seen do the install used the 340hd2.. hmm.
Old 03-10-2021, 01:24 PM #26
How old is your TPS? That runs the whole show from gear selection to kicking down to fuel and ignition timing maps.
Old 03-10-2021, 01:27 PM #27
Real Name: Patrick
Real Name: Patrick
There's a write up on the 340hd2 kit: Transgo 340-hd2 install and reveiw The 340hd2 kit has 2 ways you can modify the valve body. Either truck or race shifts with truck being softer than race shifts. You might try asking the OP what he thinks of it since it's been a few years on his install.
Old 03-10-2021, 07:33 PM #28
T4topher's Avatar
T4topher's Avatar
Saw that one, there is a pretty detailed write up on Tacoma world as well. I just wish someone had a review of the sk340. I might call transgo and just see what they say about it/recommend. Probably try to message OP as well just to see what he says.
TransGo A340 F (4x4) Valve Body Shift Kit Install (with pictures) | Tacoma World
Brand new oem toyota with less than 500 miles on it.
Old 03-23-2021, 07:18 PM #29
ocbruin ocbruin is offline
ocbruin is on a distinguished road
My 2001 had the same issue. Cleaned the maf and hooked it up to a multimeter and everything was within spec's. I ordered "returned" maf on amazon hooked it up to a multimeter and it behaved differently than my old one.
I put it in the car and symptoms resolved. Definitely try a new maf.
FS: 3rd GEN 4wd sr5 - white exterior/tan interior, $4000 orange, ca
2001 Toyota 4Runner - Cars & Trucks - Orange, California | Facebook Marketplace
ocbruin is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 06:29 PM #30
T4topher's Avatar
T4topher's Avatar
Only reason I’m hesitant on getting a new MAF is because my buddy let me borrow his and it didn’t change a thing.. Also my testing procedure of shifting into different gears really narrowed it down IMO, it wouldn’t happen at all when it was stuck in 1st gear.. I ordered 2x shift solenoids (the over drive solenoid was $$$) and the transgo kit. Really hoping this does the trick.
ebay , hesitation , kit , maf , tested
98 4r with bad hesitation under acceleration hardtime 3rd gen T4Rs 23 02-14-2024 03:21 PM
Acceleration Hesitation Norcal_Mike 5th gen T4Rs 75 02-11-2019 10:49 PM
Acceleration hesitation from stop joshik 4th Gen T4Rs 14 06-30-2018 02:48 PM
hesitation during acceleration joshik 4th Gen T4Rs 1 04-07-2016 02:57 PM
hesitation in acceleration Craig11909 5th gen T4Rs 5 06-22-2015 06:44 PM
