Old 03-26-2021, 10:22 AM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by T4topher View Post
Only reason I’m hesitant on getting a new MAF is because my buddy let me borrow his and it didn’t change a thing.. Also my testing procedure of shifting into different gears really narrowed it down IMO, it wouldn’t happen at all when it was stuck in 1st gear.. I ordered 2x shift solenoids (the over drive solenoid was $$$) and the transgo kit. Really hoping this does the trick.
Did you ever figure out the difference between the two transgo kits? Which kit did you end up going with?
Old 03-26-2021, 11:52 AM #32
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I ended up just going with the one that everyone else went with 340hd2. Kind of want to supercharge it someday anyways so figure the HD kit is probably the way to go.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 11:04 AM #33
T4topher's Avatar
T4topher's Avatar
Welp I got the supercharger installed but still haven’t been able to figure this problem. Shift solenoids didn’t fix it. I did find a bad shift solenoid when I replaced them though. Kind of thinking it’s the tps or the wiring to the tps. Either that or the ECU.
Old 02-08-2024, 09:51 PM #34
Jason B's Avatar
Jason B Jason B is offline
Official Vendor
Jason B is just really nice Jason B is just really nice Jason B is just really nice Jason B is just really nice
Official Vendor
Jason B's Avatar
Originally Posted by ocbruin View Post
I put it in the car and symptoms resolved. Definitely try a new maf.
@T4topher I think new appropriate maf is your next step
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
jason@burtmanindustries.com
DO NOT PM - text/call 717-319-2100 (24/7)
Jason B is offline   Reply With QuoteReply With Quote
Old 04-07-2024, 11:26 PM #35
GrantsRNRS GrantsRNRS is offline
GrantsRNRS is on a distinguished road
Edit: I’ve narrowed it down a little, it only happens between 1st-2nd gear shift (roughly 1500 rpm) when coming out of a stop. If I put the auto shifter into L (1st gear) it will not do the hesitation. Kind of leaning toward this being something with my ECU or throttle body/throttle position sensor or the wiring for them. It’s pretty consistent and repeatable. Thinking about taking it to the dealer for diagnostic but I know that can be questionable.
This has been plaguing me for a while. When I do a rolling stop/stop very shortly and accelerate i get a slight hesitation. It revs for a split second then it seems like it dies a little then picks right back up. If I do a full stop and wait a second it won’t do it. Ive done quite a bit of maintenance on this thing so I have a decent head start on narrowing this down hopefully.. i try to stick with oem toyota parts where I can.
Any suggestions/recommendations would be helpful!
2000 limited 5vzfe 184k miles no CEL and drives 100% fine except for this issue.
Here’s the relevant things I’ve done so far:
Replaced:
-plugs/wires
-fuel filter
-air filter
-timing belt (eBay kit Tim recommended)
-valve cover gaskets/pcv
-automatic transmission solenoids (all 3)
-throttle position sensor (got a CEL to replace this)
Cleaned/rebuilt/tested:
-cleaned/rebuilt injectors (eBay kit)
-cleaned/swapped/tested MAF
-cleaned/tested IAC
-cleaned throttle body/intake manifold
-coil packs tested per FSM
-cleaned electrical connections on TB/MAF/TPS
-over drive/ect have no effect on this problem
Did you ever solve this problem? I can’t figure it out.
96’ SR5 Manual 4x4 / 97’ Limited Auto 4x4
GrantsRNRS is offline   Reply With QuoteReply With Quote
Old 05-13-2024, 08:53 AM #36
T4topher's Avatar
T4topher's Avatar
Never was able to figure it out, kind of thinking it might be the ecu but who knows.
ebay , hesitation , kit , maf , tested
98 4r with bad hesitation under acceleration hardtime 3rd gen T4Rs 23 02-14-2024 03:21 PM
Acceleration Hesitation Norcal_Mike 5th gen T4Rs 75 02-11-2019 10:49 PM
Acceleration hesitation from stop joshik 4th Gen T4Rs 14 06-30-2018 02:48 PM
hesitation during acceleration joshik 4th Gen T4Rs 1 04-07-2016 02:57 PM
hesitation in acceleration Craig11909 5th gen T4Rs 5 06-22-2015 06:44 PM
