02-25-2021, 02:03 PM
RPM drop/rebound ?
Over the last week or so, I've noticed something that I can reliably reproduce.
I'm in a 2000 automatic 4wd. I've had the truck for about 2 months now. I don't remember noticing this issue until about a week ago, but it's also possible (likely) I wasn't paying attention to it.
Anyway, with O/D Off, at about 1500 RPMs and 35 MPH, I'll experience a momentary rev drop/rebound when I apply brakes.
Here's the full picture:
Recent work (within last year, previous owner and myself):
- new radiator
- new valve cover gaskets
- new timing belt
- new battery
- new water pump
- new driveshaft
- new cat
- recent oil change
- power steering fluid exchange
- new starter
- new MAF sensor
- new spark plugs
- new coil boots
- new pcv valve
- new fuel filter
- cleaned throttle bottle/IAC
- fixed various vacuum leaks (one that thew a P0171 and another that prevented my 4WD from engaging)
Things that don't seem to matter (this happens either way):
- Coolant temp
- ATF temp
- ECT norm/pwr
Pre-conditions:
- O/D Off
- 3rd gear
- Cruising about 35 mph
- RPMs about 1500
Steps to reproduce:
- Apply brakes to slow down to about 30 mph
Symptom:
- The moment I brake, the engine quickly drops to about 900 RPM before correcting and quickly climbing back up to about 1200 RPM.
Torque converter?
Any thoughts? Something about locking/unlocking/re-locking the torque converter? since i'm in O/D Off, then brake, but not enough for a downshift? Trans fluid is at the correct level, looks pretty nice and red. I'll be adding a Magnefine filter shortly, doing a drain & fill, and adding a B&M external cooler in series. Have not tested this with 4wd engaged.
Also, is this something to be worried about?
Thanks!!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
02-25-2021, 02:16 PM
Originally Posted by cl4Rk
Anyway, with O/D Off, at about 1500 RPMs and 35 MPH, I'll experience a momentary rev drop/rebound when I apply brakes....
No idea why.
But why drive at 35mph with OD off?
I only turn OD off when climbing or I need to pass another vehicle at highway speeds, it does not help my vehicle's performance at 35mph. I can't find another time to use it that it makes a difference but hey who knows....
02-25-2021, 02:20 PM
Thanks for the reply.
Why OD off at 35mph? No good reason. Just experimenting and learning as I go. I've been really enjoying fixing up this truck, and this forum has been massively helpful.
@Y2K_4X4
02-25-2021, 03:37 PM
Real Name: Patrick
Real Name: Patrick
Torque converter locking/unlocking under those specific conditions would be my best guess
02-25-2021, 03:56 PM
The torque converter is not locked at 35mph, OD on or off.
It does have something to do with the torque converter going from loaded under power to coasting. I mostly notice mine doing it in 4th/OD going from cruising to coasting.
Not 100% sure it is normal, but it hasn't caused any problems with my truck in the last ~300k miles...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-25-2021, 04:54 PM
Real Name: Patrick
Real Name: Patrick
Do you know what mph the torque converter will lock up with overdrive off?
02-25-2021, 09:04 PM
I’d also be interested in the answer to this.
@Y2K_4X4
02-26-2021, 09:47 AM
Real Name: Patrick
Real Name: Patrick
Depending on the load my torque converter will lock up with overdrive off at around 36 mph
02-26-2021, 04:52 PM
Officially from the Toyota manual (OD on) (for V6 4WD):
Code:
Lock−up point (Throttle valve opening 5%), O/D gear (NORM and PWR)
Lock−up ON 72 − 78 km/h (45 − 48 mph)
Lock−up OFF 65 − 71 km/h (40 − 44 mph)
It doesn't have a spec for when OD is off, but in my experience it is about 5mph lower and will hold for higher throttle openings.
02-26-2021, 04:56 PM
Real Name: Jerod
Real Name: Jerod
Double check your brake booster vacuum hoses for cracks or loose fitment. Do you also get too soft of a brake or too firm of a brake at the same time?
Mine revs down but never down that low. More like to around 1200 RPM's at the lowest.
02-26-2021, 07:36 PM
Hmmm great question. I’ll check for brake feel during this maneuver. I want to say I get a soft brake feel, but I’ll test it out.
All my vacuum hoses are pretty worn out, being 21 years old.. I recently ordered this silicone hose kit and will be replacing all my hoses soon.
@Y2K_4X4
02-26-2021, 07:47 PM
Only when you hit the brakes the drop/rebound happens?
What about just cruising along then taking foot off the gas pedal, no rpm drop/rebound happens?
02-26-2021, 08:17 PM
Yep. Only if I use the brakes. Doesn’t happen if I let of the gas as far as I remember. I will double check that scenario though.
I mostly notice it after I crest a hill and begin the descent, but traffic ahead prevents me from continuing at the same speed, so I push the brake to slow down a little.
All day today I kept O/D On, and did not experience this at all.
@Y2K_4X4
02-26-2021, 08:57 PM
Update: was just able to test. Brake feel is normal.
@Y2K_4X4
02-26-2021, 08:58 PM
Update: confirmed that it only happens in this very narrow set of circumstances, only when I hit the brakes. Letting off the gas does not reproduce the issue.
@Y2K_4X4
