Old 02-26-2021, 11:23 PM #16
HiLife HiLife is offline
Originally Posted by cl4Rk View Post
Update: was just able to test. Brake feel is normal.
Try letting the truck sit for a while. Without starting the truck...step on the brakes. You should have vacuum assist on the first push of the brakes and gradual hard on the second push.
You could have a leaking brake booster check valve or leaking booster. Bottom line is booster cannot hold vacuum.
Old 02-26-2021, 11:41 PM #17
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Ok I’ll check it soon and post my findings. Thank you!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 10:49 AM #18
Pinch off the vacuum line to the brake booster and see what happens.
Old 12-01-2021, 01:56 PM #19
cl4Rk's Avatar
cl4Rk's Avatar
Just to update this thread, I have not really noticed this symptom since finishing the frame swap. So I won't be able to get to the root cause unless it starts happening again.
@Y2K_4X4
Old 02-08-2023, 04:01 PM #20
AntonioCm1983's Avatar
AntonioCm1983 AntonioCm1983 is offline
Real Name: Antonio Claudio Michael
AntonioCm1983 is on a distinguished road
Hey everyone Check your Coils you could have a failing coil and the coil is working and as your slowing Down the coil looses power then regains Power and Current spikes on the secondary winding after recovery seen this on Cylinder 1 coil and because it's a waisted spark system 2 cylinders are loosing power momentarily and then recovering to fast for a misfire..... hope it helps all if you need coil ohm specs let me know....
Over the last week or so, I've noticed something that I can reliably reproduce.
I'm in a 2000 automatic 4wd. I've had the truck for about 2 months now. I don't remember noticing this issue until about a week ago, but it's also possible (likely) I wasn't paying attention to it.
Anyway, with O/D Off, at about 1500 RPMs and 35 MPH, I'll experience a momentary rev drop/rebound when I apply brakes.
Here's the full picture:
Recent work (within last year, previous owner and myself):
- new radiator
- new valve cover gaskets
- new timing belt
- new battery
- new water pump
- new driveshaft
- new cat
- recent oil change
- power steering fluid exchange
- new starter
- new MAF sensor
- new spark plugs
- new coil boots
- new pcv valve
- new fuel filter
- cleaned throttle bottle/IAC
- fixed various vacuum leaks (one that thew a P0171 and another that prevented my 4WD from engaging)
Things that don't seem to matter (this happens either way):
- Coolant temp
- ATF temp
- ECT norm/pwr
Pre-conditions:
- O/D Off
- 3rd gear
- Cruising about 35 mph
- RPMs about 1500
Steps to reproduce:
- Apply brakes to slow down to about 30 mph
Symptom:
- The moment I brake, the engine quickly drops to about 900 RPM before correcting and quickly climbing back up to about 1200 RPM.
Torque converter?
Any thoughts? Something about locking/unlocking/re-locking the torque converter? since i'm in O/D Off, then brake, but not enough for a downshift? Trans fluid is at the correct level, looks pretty nice and red. I'll be adding a Magnefine filter shortly, doing a drain & fill, and adding a B&M external cooler in series. Have not tested this with 4wd engaged.
Also, is this something to be worried about?
Thanks!!
AntonioCm1983 is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 04:18 PM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I hope he hasn't been waiting for 2 years for your response lol
Old 02-13-2023, 02:49 PM #22
cl4Rk's Avatar
cl4Rk's Avatar
Thanks for your reply, although this hasn’t happened for a couple years now since the frame swap..
@Y2K_4X4
Old 02-14-2023, 10:39 AM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe a bad ground issue that was addressed in the frame swap.
4wd , mph , o/d , rpm , valve
RPMs drop/rebound while driving 4Runner4TW 3rd gen T4Rs 2 09-27-2021 01:38 PM
Icon Rebound On Sale drei4runner29 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-20-2019 10:23 AM
anyone got the Icon Rebound wheels? stephan07 5th gen T4Rs 1 01-12-2019 07:19 PM
17” SCS SR8 or ICON Rebound pictures/figment DatYoda 5th gen T4Rs 4 06-04-2018 02:59 PM
Rebound and compression test of rear shock ron in sc 5th gen T4Rs 8 02-02-2014 06:45 PM
