Old 02-20-2021, 12:33 PM #1
steadyeddie steadyeddie is offline
steadyeddie is on a distinguished road
ADD functionality question
I am seeking information on the ADD of GEN 3 4Runners. Specifically, when the ADD is in disengage mode, is there any rotation of the shaft connecting to the transfer case? Do the front half shafts basically free wheel? Thanks to all in advance for any information and for your patience!
steadyeddie is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 06:25 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I think this explanation is relevant? (somebody correct me if I’m wrong): Toyota Tech: Defeating the ADD System
I know that when I’m in 2WD (and parked) I can rotate the front propeller shaft freely by hand, and when parked in 4WD, it’s locked in position.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 02:40 PM #3
The CVs on each side always spin at the speed of the front wheels. The only disconnect is between the passenger axle and the front diff. The driver's side axle is still connected to the 'inner' part of the differential. The only part that 'free wheels' is the prop shaft back to the transfer case.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-26-2021, 05:29 PM #4
Hi there, I probably should have indicated why I am asking for the information in my original query. What I hope to do is flat tow my 4Runner. I know that others have stated that this should not be done and that the factory says NO. I am thinking that if I remove the slip yoke from the rear drive shaft and anchor it up, and make sure that the ADD is in disengage mode up front that the tranny will not be driven when the vehicle is towed. Am I on the right track? Thanks again for you input.
Old 02-26-2021, 05:52 PM #5
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
There is no slip yoke, 4bolt flange at both ends, I would remove the rear drive shaft completely for safety and damage control reasons, I guess you can disconnect it from the rear diff and put the tcase and Tranny in neutral, the front drive shaft will be disconnected, and the front CV's will freewheel, but for 4 extra nuts/bolts I'd remove the rear driveshaft if travelling any distance.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 08:56 PM #6
Yes, that should generally work. I believe some company made (maybe still makes?) a rear output disconnect that would do what you are looking for to - depends on your budget and how often you will be dealing with the rear prop shaft.
Maybe I'm thinking of this, but it won't work for our transfer case:
Rear Drive Disconnect, For Toyotas - Trail Tough
Old 02-27-2021, 09:01 AM #7
Thank you! I am still on the fence about flat towing or using a "dolly" for the front end, but in any event removal of the drive shaft sounds like the safest way to go.
add , advance , information , question , wheel
Fully Enabled Nav Functionality! DennisW 5th gen T4Rs 61 06-25-2014 01:22 PM
Hood Scoop functionality boostedhb 3rd gen T4Rs 16 03-02-2011 04:15 PM
Factory NAV functionality in T4R chatham 5th gen T4Rs 16 11-18-2010 06:14 PM
New Search Functionality admin Announcements - Terms & Conditions of Use - Privacy Statement 2 11-05-2010 01:51 AM
iPod functionality of the AVIC D-3 RainCityRunner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-08-2007 02:33 AM
