Old 02-27-2021, 09:36 AM #1
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
Rear Axle compatibility diff yrs?
would rear axles from a 96 Limited fit my 99sr5? both 4WD not sure that matters.
garn79 is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 12:35 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Yes, as long as they are both abs equipped, not that I've seen Non ABS 4R, and they are the same on both sides except the backing plate and even the backing plate can be drilled out to accept the bell crank. There was bearing change in 01-02.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 01:25 PM #3
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
sweet thx Malcolm!
Old 02-28-2021, 08:34 AM #4
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
The only things to watch out for are ABS vs non-ABS and the brake line mount points. The ABS is the only deal breaker in my opinion. I swapped my 2001 axle to a 1997 e locker axle a few years ago. The brake lines for my 2001 had an extra mount point that the 1997 axle did not have so I used a zip tie. The brakes have not had any issues; just to not be surprised when you see this.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 02:26 PM #5
That's an issue for 01/02 vs. 96-00 rear brake lines - not an ABS vs. non-ABS issue. The 01/02 have a 4-channel ABS system instead of the earlier 3-channel system and use an extra rear soft brake line.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-02-2021, 08:19 AM #6
tx_shooter's Avatar
tx_shooter's Avatar
I did not say the ABS and brake lines were a single issue. The "and" in my sentence separated them as seperate items. I'm not an Internet idiot. Please check your reading comprehension before trying to correct other people. Before you try to correct the OP for saying "rear axles" I am sure he understands that a 4Runner only has one rear axle per vehicle.
Old 03-02-2021, 02:34 PM #7
Don't get those panties in a bunch... I never called you an internet idiot - though if you take a clarification personally, maybe you are not used to the internet?
Old 03-02-2021, 03:57 PM #8
Malcolm99's Avatar
Malcolm99's Avatar
When someone asks if the rear axles from a 96 fit a 99 we can assume he is referring to the 2 rear axle shafts in the axle housing that connect to the 3rd member, and the only concern he should have is whether it has abs rotors for those years. He didn't ask if a complete axle assembly fit. I know assuming is not wise, but the OP was pretty clear IMO. Note that I mention the axles are the same for both sides, deep breath everyone.
4wd , 99sr5 , fit , limited , rear
2001 4runner Front Diff and Rear axle/Diff assembly. Corpus Christi, TX zwalker16 For Sale: T4R Items 5 08-24-2018 09:53 AM
97 Ltd 4wd no e-locker rear diff 3rd Member stuck on axle housing; Broken diff stud. azcat90 3rd gen T4Rs 19 09-08-2016 12:07 PM
Rear Axle compatibility? mustangn6 Classic T4Rs 10 09-28-2014 09:41 PM
WTB: Rear Axle / ABS / 4.10 / No Diff Lock bigwalleye Want to Buy/Trade 1 04-10-2012 12:25 AM
Rear axle housing compatibility Nelsonmd 3rd gen T4Rs 4 09-23-2010 09:56 AM
