Originally Posted by phattyduck
The output shaft of the 2WD needs to be swapped out for the 4WD output shaft. Otherwise, the transmissions should be compatible. You may also need to drill and/or tap a couple holes for the the transfer case adapter to bolt on to the 2WD case. You will also want to swap over the larger 4WD trans pan/filter/diipstick to the 2WD trans.
The output shaft swapping isn't a simple task - you can probably find a walkthrough thread on here.
What Charlie said.
And this...
A340E to A340F Transmission Swap
Do note that technically the valve bodies are different for too.
