02-27-2021, 12:19 PM
Real Name: Bob
Real Name: Bob
Skid plate that covers the catalytic converter
I've searched the posts on here and I don't believe it exists but, I'm hoping to find a skid plate that covers access to the catalytic converter.
One of my Honda sedans got its Cat stolen the other night so, it's on my mind.
I've looked at the CatClamp and CatStrap and I may go that direction on the Hondas. But, for the 4Runner, I'm looking for hopefully a skid plate.
99 Limited, 3.4L, 4x4 without running boards or sliders.
Any ideas if any manufacturers have a bolt on solution?
Taking into account heat dissipation, any other ideas? I understand that it may be a custom fabrication.
Thanks
02-27-2021, 08:39 PM
Sorry to hear about your cat getting stolen.
There have been a lot of discussions about this over the years. Seems like there’s no good off-the-shelf solution for our trucks.
Maybe, if you install a full coverage skid like CBI or RCI, then maybe adding additional plates that cover the rest of the cat. The plates could be welded to the frame? For heat dissipation, add a bunch of holes in it like the factory gas tank skid?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
02-27-2021, 10:17 PM
Had 5 cats stolen off my Toys 2 years ago. Not cool! No skid plate just for cats. You would have to custom fab that. Some people weld rebar onto their cats so they are harder to cut off with a sawzall.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
02-28-2021, 05:35 AM
Bud Built
Bud Built 2 piece skid plate covers the catalytic converter. Also the original 3rd Gen Skid Plate.
Dave S
02-28-2021, 08:43 AM
From this thread: BudBuilt Skid Plates
Originally Posted by the great him
i just went out and looked at mine, id say they cover more like 50-60%. it would not be impossible to remove the cat, but it would slow some one down or make them think twice about trying it...
@Y2K_4X4
02-28-2021, 01:43 PM
I went the steel rod method, had my muffler guy install them all over the cats on a sequoia, 4runner, camry, kia and a prius, about $150 for all of them.
Sure they can be cut yet with a fair amount of noise (about 8 rods per cat) my bet is the average thief will move onto an easier target and thus I sleep better, ahh.
02-28-2021, 03:09 PM
Real Name: Blair
Real Name: Blair
8 per Cat? Jeez - I was thinking about 1 length of rebar or 2 max.
02-28-2021, 03:16 PM
My old 18v dewalt grinder goes through rebar in 2 seconds. Definitely need something stronger.
02-28-2021, 04:21 PM
Real Name: Blair
Real Name: Blair
Yep, I have the 20V Max version.
03-16-2022, 02:00 AM
Thanks
I think this company has what you're looking for.
Catalytic Anti Theft Shields and Converter for Toyota Tundras, Sequoias by ADD Automotive
03-16-2022, 06:14 AM
Real Name: C8H18 Mike
Any skid plate kit that covers the engine, transmission and transfer case will prevent easy access to the cat(s) - the bottom engine cover offers little protection.
I have RCI (powder coated) skids but the Coastal Offroad kit might be cheaper if you don't mind panting it yourself.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
03-16-2022, 12:09 PM
I have a federal emission runner so IDK the placement on your ( likely CA emission based on the fact your in Burbank) cats are. My trail gear trans crossmember/tcase skid cover the cat to the rear O2 sensor but left the front half exposed. Because of my trail gear cross member there is no trans skid that a company makes so I made a custom trans skid to go from my engine skid to the trans cross.
With that said I also have a rod cage welded around the cat. one leg at the front and one at the rear weld it to the inside of the frame. The legs on the inside section of the vehicle run to the trans skid that has a mounting tab that uses a nut and bold to secure.
I did this after my neighbors sequoia's cat was stolen. On his I was able to place a 3/16" plate the width of the underside of the cat and weld bars straight to frame points to secure. So its basically a cat skid
don't know if that helps...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
03-16-2022, 12:24 PM
Real Name: Blair
Real Name: Blair
Photo?
03-17-2022, 02:57 AM
Real Name: Keith
Real Name: Keith
Some good info here.
Since, to cut a single cat out of an exhaust pipe requires making a cut both behind AND in front of the cat, one only has to protect EITHER the pipe in front or the pipe to the rear from being cut. On my '97, the segment at front of the cat is much, much shorter than the segment to the rear...so that's where I'm looking to create some protection.
If the creeps make one cut and realize they can't proceed, it's a small welding job to repair their failed attempt.
03-17-2022, 10:31 AM
No - I meant he put 8 pieces of rebar on each cat, each piece varies but about 6-8 inches.
He took time to find places and different angles so cutting them would be take some time, hopefully they'll just move on to easier targets.
But like they say, if they Really want something, nothing can stop them.
i call them Leaches of Life.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
