Old 02-28-2021, 01:35 PM #1
maddss maddss is offline
Real Name: Scott
maddss is on a distinguished road
Real Name: Scott
What’s wrong w/ my 4runner part 2
99 Limited, 266k, Factory alarm? No CEL
Back history, Randomly the alarm would start, flashing headlights n Horne until the battery died. Once the battery was charged the truck would attempt to start with no key in the ignition. Unk if this fixed
Today’s new problem
In Park
The motor will turnover, start, the starter stays engaged
Shift the transmission into Neutral, the starter engages.
Shift the transmission into reverse or Drive, the starter disengages
If I switch the truck back to into neutral, the engine shuts off.
Once the The truck has been running for 15 minutes or more in drive, you can put it back in park or neutral and the starter will not engage. However the truck will shut off immediately.
maddss is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 02:02 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Being a ltd, you would have Toyota's Immobilizer system, it should say so on the ignition ring. Has someone added a remote start and/or piggy backed an alarm system. If not you will need to go over your ignition wiring and look for a open short to open power.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 02:25 PM #3
Real Name: Scott
Real Name: Scott
Only thing on the ignition ring is Toyota Security. It also has the red LED security light on the upper center console.
There is no secondary remote or starter. I have looked everywhere
Old 02-28-2021, 02:28 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I would tend to agree with Malcolm99. Check for an aftermarket alarm or remote starter. Sometimes they will fail and the vehicle won't start or will start when not turned on, or the alarm will go off for no reason. Also check starter relay, park/neutral switch and ignition switch although they aren't likely the problem.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 02:36 PM #5
MaineRunna's Avatar
MaineRunna's Avatar
Did you pull the driver's side knee bolster panel down? Typically that lower removeable panel has to be removed to install or remove a remote starter.
I did have a Corolla do something very similar a while back and it turned out to be the park/neutral switch. I think the key had to be turned on though. It would start itself as soon as the key was turned on and the starter would keep running until put in reverse or drive, it would also stall when put back in park or neutral. It is the only vehicle I have ever ever worked on that acted like that due to the neutral safety switch.
Old 02-28-2021, 02:43 PM #6
HiLife HiLife is offline
Would it be possible to post a pic on here of your wiring?
Especially around the fuse box area?
Except for the neutral start switch, which only cuts power going to the starter circuit. It would take human intervention to bridge, and power that circuit. Toyota back in the day didn't have remote start as an factory option unless it was added on later as the above said.
Old 02-28-2021, 06:36 PM #7
Real Name: Scott
Real Name: Scott
Fuse panel
I can only get 1 pic to work
-img-5424-jpg
Old 02-28-2021, 09:06 PM #8
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Does it do this with the valet key while the ‘smart’ keys all have their batteries removed?
thennen is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 10:17 PM #9
Real Name: Scott
Real Name: Scott
I dont have a valet key. Only have 2 master keys
Old 02-28-2021, 11:27 PM #10
thennen's Avatar
thennen's Avatar
Did you try removing the batteries from both keys then?
Old 03-01-2021, 02:16 PM #11
phattyduck phattyduck is online now
The immobilizer keys do not use a battery. Nothing to unplug.
The images should be posted to an external hosting site and linked here if you want high resolution to work (imgur or similar).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 03-01-2021, 06:13 PM #12
thennen's Avatar
thennen's Avatar
Oops, my bad. Thanks.
back , neutral , start , starter , truck
Is something wrong with my 4Runner? _westtexasrunner_ 5th gen T4Rs 33 02-06-2020 01:23 PM
1998 4Runner Shifter Bushing and Seat Part (Canada). Can I use 2nd Gen Part? nobb 3rd gen T4Rs 6 02-03-2013 11:11 PM
dealer said my part #s are wrong and none shows up silversx 5th gen T4Rs 4 09-19-2011 07:50 PM
fugly 4Runner ,that's just wrong imo NOT ME OR SOMEBODY 3rd gen T4Rs 15 09-04-2011 04:43 PM
5100 Install HUGE Problem/Wrong Part? aviator31 4th Gen T4Rs 7 08-20-2011 05:39 PM
