Old 02-28-2021, 04:18 PM #1
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
LED bulbs
Hi all,
I was on Amazon recently and started looking at LED bulbs for the 99.
Can anyone give me some of their experience with them. Do they have a high beam / low beam? Any recommendations would be good too.
Thanks
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 05:15 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
AFAIK if it didn't come with LED headlights it is illegal to add them in North America to a halogen headlight bucket unless for off-road only use, as it will blind on coming traffic which could lead to an accident or head on collision and even if the LED's are not the cause of the accident and they look into it you could be considered at fault. But saying that any aftermarket lights above the bumper in many areas are suppose to have a cover over it for public road use and I don't see anyone getting pulled over for that.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 06:06 PM #3
T4Rscott's Avatar
T4Rscott's Avatar
I hear you. Where I live, it’s common. The commercial truck I drive, has LEDs and people flash me all the time. I’m not worried about it. I want to know if they would work.
Old 02-28-2021, 06:54 PM #4
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Here's a crazy idea, totally out of left field: swap them out, and be courteous to others.
In regards to our vehicles, they work out fine I believe, a friend of mine had LED headlights before he sold his 4R. The law is actually more because halogen housings usually projects LEDs horribly, but some people are able to get away with it more than others. "Not all light is the same," as they say. As said it's something that almost definitely won't be a concern unless you're involved in a wreck where it possibly could've contributed. It's fairly common to do where I live too, and I have some a**hole cops around but I've yet to know anybody that's been pulled over for having them
Devbot is online now   Reply With QuoteReply With Quote
Old 02-28-2021, 09:33 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The LED's have two modes: shine in other driver's eyes, and light up the treetops. They don't work in our halogen housings and spray light everywhere. Everywhere you don't want it, that is.
Most cost efficient lighting upgrade is to buy a set of aftermarket headlamp housings and put over wattage bulbs in it. Stock is 60W/55W. You can find 65W/60W that are a bit brighter.
326WHP 347TQ
Old 03-01-2021, 01:10 PM #6
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
This. Some good info here Drop-in headlight upgrade?
The reason people think "plug and play" LED (and HID) bulbs is brighter is due to the increase in glare/scatter from the beam pattern being screwed up by those light sources. Think of it as basically driving with your high highbeams all the time...yup you can see better at the expense of oncoming drivers.
If you want more highbeam performance you can hide a 14" or so LED light bar behind the grill. I have a spot/flood combo from Harbor Freight wired to a relay triggered by the highbeams, going to wire a switch to it though since it's overkill for driving through the suburbs or flash-to-pass in the daytime.
Old 03-02-2021, 02:24 AM #7
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Before medical school, I was an EMT. I've scraped more than a few folks (or what was left of them) off the asphalt that "weren't worried about it." You're not likely to get a lot of good recommendations for headlights that are going to present a hazard to other drivers from the forums. If you want to increase your light output for safety, consider retrofit projectors.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 12:32 PM #8
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
LED bulbs
I use to agree that LED bulbs do not work in halogen housing units. Till someone came over to buy my running boards and pulled up in his 02 4runner with these LED bulbs installed.
AUXITO H4 9003 LED Headlight Bulbs, 12000LM Per Set 6500K Xenon White for High and Low Beam Hi/Lo Plug and Play, Pack of 2 Amazon.com: AUXITO H4 9003 LED Headlight Bulbs, 12000LM Per Set 6500K Xenon White for High and Low Beam Hi/Lo Plug and Play, Pack of 2: Automotive
I immediately asked him where he got those LED’s because they weren’t pointed into the sky or way off. Shortly after, I bought a pair and they work great, including the high beams! In the last 3 months I’ve had them installed I have not been flashed once by oncoming traffic at night. Only thing left to do is the fog light mod, because when I try to turn on my fog lights they don’t work and my high beams come on.
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 03-03-2021, 12:28 AM #9
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I too use auxito and hikari leds, both are designed to mimick the light output of halogens so the oem reflectors can do their job of not lighting up trees or rear view mirrors.
I've installed them on my runner, camry (03), sequoia (15), used them for about 3+ years and not once has anyone flashed the lights at me. Far more light dispersion, even cutoff left to right, much brighter and provide confidence down a dark highway.
Old 03-05-2021, 09:35 PM #10
T4Rscott's Avatar
T4Rscott's Avatar
These are what I bought. So far I’m impressed. No one has flashed me yet.
AUTOONE H4 9003 HB2 Hi/Lo LED Headlight Bulbs, Adjustable Beam 12,000LM Canbus Plug and Play for High Low Beam 6000K White, Pack of 2 Amazon.com: AUTOONE H4 9003 HB2 Hi/Lo LED Headlight Bulbs, Adjustable Beam 12,000LM Canbus Plug and Play for High Low Beam 6000K White, Pack of 2: Automotive
Old 03-11-2021, 09:59 AM #11
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
I use Hikari also without any incidents or problems.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Maxxis MT-762 Bighorn 255/85/R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 12:34 PM #12
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
LED projector retrofit and be done with it. Not that expensive or that hard. My BX Built projectors are absolutely amazing with 3x or more the visibility of stock headlights.
JZiggy is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 08:57 AM #13
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
DO NOT put led's in reflector lamps!!!
This will just make them ridiculously glaring to everyone else and will look aweful.
if by chance you like me and you don't want to swap out the original headlights, just either get some slightly brighter bulbs, or just get yourself some kind of auxiliary lights that you can turn on and turn off
Old 03-12-2021, 09:37 AM #14
Trophy_Rock Trophy_Rock is offline
Trophy_Rock is on a distinguished road
Another vote for BxBuilt
Trophy_Rock is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 11:31 PM #15
fullmoonguru fullmoonguru is offline
fullmoonguru is on a distinguished road
I use Beamtech. The pattern is fine.
fullmoonguru is offline   Reply With QuoteReply With Quote
beam , bulbs , experience , high , led
FS: TRS 9006: MORIMOTO ELITE HID SYSTEM (5000K bulbs) + 3000K bulbs $70 - Bham, AL momo.75 For Sale: T4R Items 8 09-18-2015 05:22 PM
H8/H11/H16 Philips X-treme Ultinon LED Bulbs Vs Halogen Fog Light Bulbs XenonDepot Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-22-2014 10:42 AM
H3 bulbs or Halogen bulbs? Net4n6 General Discussions 2 10-12-2009 04:59 AM
Bulbs AlexJet Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-26-2005 03:39 PM
