The rear heater is a very easy to diagnose system and kinda handy, if it ain't leaking it can be made to work, or you can get the 01-02? SS rear rad lines, maybe the heat control cable is outta place or the door is jammed up.
Cut the shock shaft at the bottom of the shock tower with a grinder and zip cut blades and/or twist it back and forth till it snaps.
