Old 02-27-2021, 08:59 AM #1
VQDEK VQDEK is offline
VQDEK is on a distinguished road
Replacing just shocks or more?
I apologize in advance for yet another thread related to suspension and have read through a bunch of threads but...
Here's my situation. 02 2x4 with 230k. Bought it a year or so ago for a good price but needed lots of work. Alignment was bad, tires had uneven wear so I just drove it until it needed tires. Which is now. Running 265 70 16 and plan on keeping that size. Located in Florida.
The shocks are toast and I think they were original. Get bounce. Since i have to get tires and an alignment, now is the time to replace the shocks. Rest of suspension looks to be good from my inspection (the vehicle was originally well maintained).
I wouldn't mind some small lift but don't it's not my focus. I've read that Bilstein 5100s are a popular choice. They generally seem to be paired with OME springs. I can't really tell if my springs are bad. Although at 230k, they obviously have wear. I don't off road aside from an occasional path to a camp site so this is for basically street use.
So, for you guys that know here are my questions:
1. Should I just go get stock replacements?
2. Should I go 5100s around and keep stock springs? (I thought I read that on a 2x4 I have to go with a 2.5 lift - is that true?)
3. Should I just replace all shocks and springs? If so, is the 5100/OME combo a good one for daily driving in Florida.
Thanks in advance.
VQDEK is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 07:09 PM #2
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Not sure what your budget is/What you wanna spend but if your never gonna offroad it then id personally stick with rockauto shocks like Monroe or KYB and moog springs. Keep in mind that the rear end will probably sag even after you put new springs back there. The 5100s are a good choice but like I said I don't know if you wanna spend the extra money for them.
I know ill probably catch shit for saying use the cheap rockauto shocks and springs but that's my opinion.
If you are looking to spend money then I recommend 5100s all around with OME 906 in the back and Moog 81088 up front. Id also recommend checking out the swaybar links/bushings while your down there too
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 07:19 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I strongly suggest either KYB or OEM for regular use. I'm not sure about off roading since i'm not in that field but KYB is almost on par with OEM equipment. I haven't heard good things about Monroe - I have the rear shocks paired with Monroe on my Civic and have to replace them again after a year and a half from use. Will be using KYB next time.
2000 4Runner Limited 4x4 V6
Old 02-27-2021, 08:24 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
the kyb's are good and have used them on many different types of rigs. I did have warranty issuse with my last ones, leaking on rears. Lucky easy to replace. Did not have issuses with the front struts. Only had for about 40k untill I went with billies and a 3 inch lift.
But have been happy with KYB in the past,, 4runners, volvos, bmw's and this current rig might see kyb's as I wont be lifting this one more than 2 inches...or might go Dobinsons shocks/struts/springs.
Monroe for me have been junk, have been on other rigs I have bought and not impressed. Maybe ok for mall and street rigs.
Old 02-27-2021, 08:33 PM #5
nissanh nissanh is offline
Go with OEM shocks. KYB is not the best, and could fail soon if the shock was on a shelf for a long time.
Before you inatall gas shocks, first keep it upright and compress the shock completely 2-3 times to get gas to the bottom of the shock.
Old 02-27-2021, 10:55 PM #6
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I can confirm that Monroe is Garbage. KYB is the OEM Manufacturer for several manufacturers, Monroe is STRICTLY budget garbage that no OEM would touch.
The KYB's are a great shock and work just fine for general off-roading. I have the Mono-Max in the rear with TRD PRo 5th Gen Springs, and it rides PERFECT. No bounce, nice and solid, and no excessive roll with the old saggy springs.
I have yet to get around to swapping the fronts to KYB's and replacing the Monroe's that are up there from the PO, but I know it will make a massive differene..now if only the dang city would make up there mind on fixing my alley...been parking at the neighbors driveway for over a month now waiting
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 02:07 AM #7
hdoggie24 hdoggie24 is offline
hdoggie24 is on a distinguished road
I'm thinking of getting some KYB shocks for my 5th springs. I only drive it on the streets as my daily. Which KYB shocks are better for daily driving. The Gas-a-just or the Mono-max?
hdoggie24 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 08:38 AM #8
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
There is a lot to be said for the ride quality of custom valved shocks. ToyTec's alumaseries shocks are pretty nice but I have not heard of them being valved for the vehicle. Once I went to Kings on my 4Runner I wished I had done it years sooner. Buy once, cry once, smile every time you use it.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 09:23 PM #9
shadow247's Avatar
shadow247's Avatar
Totally agree. Kings are sweet.
The cost of my 4 KYBs was only 250 bucks. Kings are just a bit more pricy for a vehicle that sees 90 percent pavement and 10 percent dirt road.
I will be putting Kings on my truck in a few years when I can afford the 2.5LT Kit and Extended Axles to go with it!
The 4Runner Show
Old 03-01-2021, 12:59 PM #10
tx_shooter's Avatar
tx_shooter's Avatar
Funny thing is Kings improve ride and handling on both dirt and pavement. They are not a dirt only improvement.
Old 03-01-2021, 02:03 PM #11
phattyduck phattyduck is online now
Guys, he has a 2WD. If he is happy with the current ride height, he should keep the stock springs.
OEM, KYB or Bilstein 4600 will all work just fine for him. Make sure to have the appropriate stem washers (they may or may not come with the shocks).
While in there he should check for bad bushings, etc. and replace as necessary. Since it is a Florida truck, it should be rust free unless it spend time on/near the beach.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
good , read , shocks , springs , tires
replacing my shocks..... zu13 4th Gen T4Rs 11 07-20-2012 09:00 AM
replacing shocks 90runnernj Classic T4Rs 4 12-02-2009 03:53 PM
Replacing Shocks - anything I need to know? vjr021 Classic T4Rs 2 05-05-2008 03:27 PM
Help Replacing Shocks goose17 Maintenance/Detailing 3 07-10-2007 08:22 PM
replacing shocks on 03' what should I get? ajjaaron Maintenance/Detailing 1 09-25-2006 08:24 AM
