Old 03-01-2021, 12:55 AM #1
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Hazard/Rear Defroster back lit?
Quick question
On the 3Gen.. Are the Hazard and rear defroster switches Backlit?
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 01:00 AM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Originally Posted by giguchan View Post
Quick question
They are, but the hazard switch is pretty dim because of where the bulb is positioned, and if yours is burned out make sure you replace it with an incandescent because an LED won't cast light in the proper direction.
Skulking is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 01:06 AM #3
giguchan's Avatar
giguchan's Avatar
Funny thing I've been looking at these switches for ages and when it finally burnt out I wasn't sure if it was even lit in the first place.
The Orange still lights when the Defroster is activated but i do think the hazard is shot. I assume remove the Black trim to get access to the switch?
This sounds like an easy job.
Thanks.
Currently 194K
Cheers
Old 03-01-2021, 01:21 AM #4
Thanks.
You need to pull the hand brake surround, then the shifter surround, then you can pull the trim piece that the switches are mounted in. This thread does a pretty good job of showing you how to do it.
Old 03-01-2021, 11:15 AM #5
giguchan's Avatar
giguchan's Avatar
Thanks I'll give this one a go
Currently 194K
Cheers
back , defroster , hazard/rear , lit , quick
Defroster not working on back side glass lcbjr77 4th Gen T4Rs 3 12-10-2015 04:37 PM
Rear wiper/rear defroster/dome light not working... fuses? BBV 4th Gen T4Rs 5 03-12-2011 02:55 PM
Which fuse controls the Rear Defroster and Rear Windshield wiper BigK75 4th Gen T4Rs 2 10-09-2009 10:18 AM
Hazard / Rear window switched AK602 4th Gen T4Rs 1 11-29-2005 12:22 AM
