Old 03-02-2021, 02:40 AM #1
Vette468's Avatar
Vette468 Vette468 is offline
Vette468 is on a distinguished road
Vette468's Avatar
Rub,,RuB'..too Late Fenders Floppin
My 2000' Limited rides High , so I put 285s on ,,and drove gently ,,bought a 3' Lift ..Lift shows up.. Lifts not goin on till Spring ;) ..we get Dumped on with Snowfall.. Backed up my Curb and over a 3 1/2 ft Drift.. - WHAACK,, Tire hits the Lower Front Fender' ,, the Drivers side Fender is 'now" - Flappin down Low ;P .. but this thing just REVERSE" -Crawled thru a 3 1/2 foot Drift ! ! in AWD' .. not even Locked into 4wD.. with 2 Worn Mastercraft Coursers' on the rear and NEW" Iron Man" Muds on the front .. Incredible.. This Trucks a Beast .. Im the 2nd owner.. I paid $1400bux for it with 189,000 Im Lovin it ..and LOOKIN for a Early 5th GEN !.. Third GENS Rule !
Hot Rodder Car Nutt- Enthusiast for over 35 years! Biker -Builder ..Amateur GunSmith-Amateur Explosives Expert-Expert P%ssy LicQer ... E-Lock Grey Wire Mod. Rough Cunt' 3'Lift' Dick Cepek DC2s- 16x8' -12 offset" 285 75 16' IRONMAN MUD COUNTRY's '
Vette468 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 12:32 AM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot has a spectacular aura about Devbot has a spectacular aura about
Devbot's Avatar
Real Name: Devan
based schizoposter
285s will rub unless you have a 3in suspension lift and 1in body lift at the very least. Some still advise tubbing firewalls with this combo as you're likely to contact while flexing. Looks like those tires are pretty bald so remember it's only going to get MUCH worse with new ones.
Also AWD =/= 4WD.
Y2K Highlander Millennium Silver 3.4L auto @ 290k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / LED Interior / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / SS + Extended Brake Lines / Elbow Delete + ISR + O Gasket / TNF Open Wing Bumper / Smittybilt XRC Gen 3 Comp. / Diehard Platinum AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod
Old 03-05-2021, 12:27 PM #3
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek is on a distinguished road
I had 285s on my previous 4runner with only a toytec 3" lift and I had absolutely no rubbing whatsoever. No modification as well. Wheels were 8" wide with -12mm offset.
01' SR5
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 10:11 PM #4
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
oh duh 285s are 33in tires. I was thinking they were 35in for some reason
Old 03-14-2021, 09:03 PM #5
Vette468's Avatar
Vette468's Avatar
3' inch Lift is on..waitin on my diff-spacers..the damage' is done" im a Bodyman..no problem..ive already done sum Hammering on the inner wheelweels....ill get a 1 inch Body-lift on for 35s eventually
1/2 , drift , fender , front , lift
A Little Late FrogginAround 3rd gen T4Rs 3 01-31-2020 11:52 AM
01-02 SR5 fenders comtible w/ older limited fenders? silver4est 3rd gen T4Rs 0 01-28-2019 06:07 PM
Is it too late? john.diachenko 3rd gen T4Rs 16 10-25-2016 08:56 PM
Little late but... 85RedRunner So Cal 1 07-16-2016 09:19 AM
Late Feb Tahoe Run! BlackWorksInc Off-Roading 1 02-11-2013 07:23 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
