Old 03-02-2021, 11:20 AM #1
crespoh69 crespoh69 is offline
crespoh69 is on a distinguished road
A/C light is off but still blows air
I have a 99 4runner and just did a 300 mile trip over the weekend. On the way back I noticed that the A/C light wouldn't turn on and the car only blew hot air. When I finally got home I checked and all 3 belts are still there but I noticed that there was what looked like some small burnt plastic remnants around the engine bay, not sure where that's from though.
Car runs fine otherwise but with the heat coming I'd like to fix my A/C, any tips on what I should do?
crespoh69 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:52 AM #2
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
How does the ac compressor pulley/clutch look?
Bad Luck is online now   Reply With QuoteReply With Quote
Old 03-02-2021, 07:39 PM #3
How would I go about testing it out?
Old 03-02-2021, 10:56 PM #4
It's not the same vehicle but would this be a good video to test it out?
https://www.youtube.com/watch?v=k8IQnkqvXIQ
Old 03-03-2021, 10:12 AM #5
Real Name: Patrick
Real Name: Patrick
Those are some good things to check, but keep in mind there are a lot of different reasons your ac compressor may not be engaging when you request the ac to be on
Old 03-08-2021, 01:01 AM #6
So I was able to get some time this weekend to look at things and the face does spin freely by hand. I have to look for some alligator clips so wasn't able to test with that just yet, maybe next weekend.
I'm still concerned about the burned plastic/rubber though. While I was in there I looked around a bit more and saw that the plastic was on the belts and even on the underside of my hood like if a plastic bomb that threw plastic shrapnel exploded under there. Any idea what that might be from? Here are some pics:
Shared album - Hector Crespo - Google Photos
Otherwise, I've still been driving the car and it's running fine. I did upgrade my injectors last year as well as added an airraid tube.
Old 03-08-2021, 10:48 AM #7
Real Name: Patrick
Real Name: Patrick
It's hard to tell what that might be from. With it being that high up I would suspect it might be your alternator or power steering belt
Old 03-08-2021, 01:35 PM #8
azrex azrex is offline
azrex is on a distinguished road
Compressor
Do you have a photo of the front of the compressor? Occasionally when the compressor short cycles, either from too much or not enough refrigerant, it will overheat the clutch bearing with the result being bits of rubber shrapnel being expelled.
azrex is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 02:13 AM #9
Thanks, the belts look fine to me though, other than the bits of burnt plastic flakes. No tears or breakage that I can see.
Old 03-10-2021, 02:15 AM #10
I'll try to get some this weekend, been busy at work. It looks normal to me though, for a 22 year old piece of metal at least. A bit dusty and dirty but overall fine.
a/c , air , car , light , noticed
*Heat On*: Heat blows on passenger side, cold air blows on driver's side biv117 4th Gen T4Rs 4 12-21-2023 07:09 PM
Auto Heat blows cold air, manual blows warm air hoggy46 4th Gen T4Rs 0 10-20-2018 10:29 AM
Fog Light Fuse Blows When Fogs Switched On. A.Wilson013 3rd gen T4Rs 13 06-10-2015 07:10 PM
toyota hilux surf 1992 japanese inport fog light blows fuse toyotahiluxsurf Classic T4Rs 1 06-24-2012 11:02 AM
my air conditioner blows hot air and my heater blows cold air Naylene General Discussions 5 04-04-2012 02:40 PM
